| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| The fact that both keys are not working points to a fault with the car rather then the keys. A common fault on older MINI's was the rear view mirror would fail as this is the receiver for the key signal. A simple check would be to swap a mirror out a similar spec car and try it!! As for the cold start noise it is related to a lack of oil in the timing chain tensioner. The fact that the oil level has dropped suggests you might have a leak that needs investigating! Hope this helps |
| Cheers Chris for the pointers...keys are sorted now...took em to Northwest BMW nr Bolton, very good service. Weirdly all they needed were new batteries but I didn't realise that when you put in new batts theys need programming DOH!Anyhoo I'm appy it's sorted n will investigate the possible leak n in the meantime I'll jus top up regularly with oil |
| Tags: keys, rattle, remote, sensor |
| Lost keys. Spare keys set of alarm!!! grrrr | SimonSJR | First Generation MINI Cooper S | 4 | Sep 24th, 2006 07:59 PM |
| raising the dead (uh, I mean the dead pedal) | rwkeating | First Generation Interior & Ice | 4 | Jun 14th, 2006 05:26 PM |
| Lights, dead battery, programing the car and Keys | lillapoyka | First Generation Faults & Fixes | 5 | Feb 4th, 2006 04:25 PM |
| Look No Keys............. | rt55 | First Generation Faults & Fixes | 3 | Jul 8th, 2004 01:44 AM |
| dead radio followed by dead battery | pacbob | First Generation Faults & Fixes | 4 | Jan 15th, 2003 04:04 PM |
