Update (resolved) Clutch grind/growl - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 20th, 2012, 05:45 AM
Local Time: 01:19 AM
Luxembourg Male
Well, I feel stupid.
Decided to open the hood and I noticed the plastic engine cover that protects the diesel common rail was loose. Fitted it back in place - no noise. Apparently it was nothing to do with the clutch. It's weird though, I could have sworn it was coming from the bell housing and not under the hood. Always seemed to occur during the same clutch movement and everything. Engine must vibrate at a particular frequency during starting from a stop.
Very strange. It didn't sound at all like plastic vibrating. I guess I've had so many problems with this car, now I'm paranoid and over-reacting.
2009 Clubman D with approx 76,000km on the clock. Clutch and dual mass flywheel were both replaced in December 2011 (about 2 & 1/2 months ago). Car does overwhelmingly highway miles with little to no stop and go. New clutch has probably only 2500km on it, practically all highway miles.
Yesterday, I started up the car and put the clutch in. Shifter into first. Start to bring up the clutch to get going from a stop and I get a grinding/growling noise. Sounds horrible. Noise is only there when the clutch pedal is travelling. Once the clutch is fully engaged, no noise (perhaps a little bit, but noise is basically being generated during pedal travel).
Once I get out of first, there seems to be no noise (maybe a little in 2nd gear immediately after a gear change, but as the car picks up speed it disappears). No noise that I can hear in 3-6th. Doesn't seem to do it in reverse.
Shifting is smooth with no difficulty engaging gears. Power delivery seems to be okay. Clutch pedal could feel a little soft, can't really say for sure.
Any ideas as to what this could be? I mean, the clutch kit and flywheel are new and were very gently broken in. Car goes in Wednesday for a separate problem, but I may as well get them to look at this at the same time.
I'm just wondering what it could be so I can have some idea of potential cost.
Thanks.
Tags: , , ,
Exhaust Growl/Rattle at 2000 rpm Tommy_L First Generation Faults & Fixes 3 Aug 27th, 2010 03:18 PM
Deeper Growl Nath316 Second Generation MINI Tuning 4 Sep 18th, 2007 03:25 AM
'Growl' on slow-down-then-pull-away m1m0 Second Generation Faults & Fixes 13 Apr 19th, 2007 12:27 PM
clutch pedal grind Gr1zzLy First Generation MINI Tuning 6 Aug 11th, 2006 08:22 AM
MCS at idle, growl, buzz, honk and other onomatopoeia. cbudgo First Generation Faults & Fixes 3 Sep 9th, 2003 10:23 PM
