Cutting out on idle - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 5th, 2012, 03:44 PM
Local Time: 05:52 AM
United Kingdom Female
Cutting out on idle
Hi,
I have just bought a 2007 Mini Cooper S and there appears to be an intermittent fault where the car cuts out when on idle or when the clutch is held down for a period of time, for example waiting to pull out of a junction.
The rev’s seem to drop very low and before the car stalls sometimes the rev’s pick back up again but after this happens once or twice the engine management light flashes up and the car cuts out. This seems to happen more when the engine is warm rather than when it’s cold and does not happen all the time.
Has anyone else had a similar problem at all?
Thanks in advance
Old Mar 14th, 2012, 10:38 PM
I had a similar problem with my 58' Mini, the revs dropping very low then cutting out, but it was happening whilst i was driving! All the info on it and what the problem was is on the thread called 'start-stop activating whilst driving'
Old Aug 13th, 2012, 10:02 PM
same here , what was the fix ?
Hi there
I have exactly the same issue with my 2007 cooper. When its warm , as soon as I come to lights or a stop it cuts out, even restarting it will idle very low and then cut out again.
Did you find out what the problem was ? Any advice would be great.
Tags: , , , ,
help please - cutting out when wet Big Neo First Generation Faults & Fixes 4 Sep 6th, 2011 07:26 PM
Cutting Out dkta2989 First Generation Faults & Fixes 3 Oct 13th, 2010 07:55 PM
One D Cutting Out!! ONED First Generation MINI One D 19 Apr 29th, 2008 09:43 PM
wax and cutting CC1970 Maintenance & MINI Care 19 Apr 7th, 2005 03:10 PM
H/K not cutting it msenkbeil First Generation Interior & Ice 1 Apr 22nd, 2003 07:32 AM
