**HELP** Strange Window Fault ... Confused!! Hi, i'm working on a 2006 mini cooper with an electric window fault. The motor was doing the normal "click" and not moving. I have replaced the motor and regulator as one unit (changed loads in the past) but the fault stayed.
Tried resetting the window, still didn't work.
Checked for voltage at the motor (yea i know i should have started here, my bad!) and i have two lives. When the switch is pressed up, one live switches to earth, but when i press the switch down, the same live switches to earth!
After checking this a few times and scratching my head, i flipped the wiring around and this was the result:
Switch down = window down
Switch up = window down
So i put the wiring back to normal and:
Switch up = window up
Switch down = window up
I plugged the old motor in (disconnected from regulator) and had the same results.
Popped down the scrappy and picked up a switch panel (checked it worked)
Put that in this evening and.... Still doesn't work.
Has anyone had this problem?? |
