Mini Cooper S (R56) Sunroof problem - MINI Cooper Forum
post #1 of 8 (permalink) Old May 22nd, 2012, 05:59 PM Thread Starter
kaymini's Avatar
Local Time: 03:59 AM
United Kingdom Female
DIY Mini Cooper S (R56) Sunroof problem
As it's such a lovely day today (26 degrees) I tried to open the sunroof before driving home from work. The sunroof started to open and then shut itself. I tried a few times and each time, it tilts and then just slides back into the closed position.
I feel like it might be due to the heat, but surely sunroofs are designed to work in the sun? I last used my sunroof a couple of days ago, and it worked fine. I tend to only open it below 40mph otherwise it is noisy.
Perhaps it will work later today when it's a bit cooler? :/
Any little fixes I can do to stop this happening again..? Or is it completely broken now?
kaymini is offline
post #2 of 8 (permalink) Old May 22nd, 2012, 06:14 PM
Macguyvic
Macguyvic's Avatar
Local Time: 09:59 PM
Quoted: 1 Post(s)
United States Male
Mine does the same thing. With a couple of tries it will open. Of course then you get worried about if it will close. So far so good. I have an 08 R56.
Macguyvic is offline
post #3 of 8 (permalink) Old May 22nd, 2012, 06:35 PM Thread Starter
kaymini's Avatar
I tried again when I got home.. :/ No luck. I'll try it again tomorrow.
kaymini is offline
post #4 of 8 (permalink) Old May 22nd, 2012, 06:46 PM
Macguyvic
Macguyvic's Avatar
Quoted: 1 Post(s)
United States Male
The few times it has happened to me I will try 3, 4, 5 times until it opens. One time it didn't open but later it did. I've heard it's an issue with the motor but I think more like a limit switch or something. As you now if you take it to the dealer it will work fine so so far I have not asked anyone to diagnose the problem.
post #5 of 8 (permalink) Old May 30th, 2012, 10:08 AM
sam12's Avatar
My 07 Cooper does this when the car has been left in the sun. I beleive its due to a current overload to the motor since it jams against the seals and hence cuts power to prevent damage, If you apply light upwards pressure towards the rear of the front sunroof and then click the switch it should open much easier.
Hope this works for you
Cheers,
Sam
sam12 is offline
post #6 of 8 (permalink) Old May 30th, 2012, 12:03 PM
MINI's are BANG TIDY
My R56 MCS does the same. I often find that if you lean back and apply a little pressure with your hand on the rear sunroof it will give way. A grease up of all the moving parts and rails once open should help as well.
Ry
Ryanjdover is offline
post #7 of 8 (permalink) Old Jun 2nd, 2012, 10:21 AM
Local Time: 02:59 AM
United Kingdom Male View xxx4xyz's Classified Ads
Send a message via MSN to xxx4xyz
Usually in the tropical heat the UK gets now and again, the rubber seals around the sunroof swell (more inside than outside) so my top tip is - turn your A/C on let it get cool inside and hey presto - it will open no problem.
xxx4xyz is offline
post #8 of 8 (permalink) Old Jun 2nd, 2012, 12:05 PM
The wifes cooper D sunroof stuck last week, requiring an upwards push on the rear sunroof rear edge inside the car to get open. The sunroof had expanded in the sun and the rubbers were dry. A smear of vaseline petroleum jelly on the rubber seals solved the problem.
pukmeister is offline
Tags: ,
Mini Sunroof Problem R56 - 07 Plate Mini Cooper DemetrisV Second Generation Faults & Fixes 26 Dec 8th, 2016 08:13 PM
Mini R56 panoramic sunroof problem dean_ham Second Generation Faults & Fixes 18 May 15th, 2016 12:40 AM
panoramic sunroof problem harvey94 First Generation Faults & Fixes 28 May 14th, 2012 09:49 AM
Dual Sunroof problem reminiscink First Generation Faults & Fixes 1 Mar 29th, 2011 11:20 AM
Sunroof problem Patchoulian First Generation Faults & Fixes 5 Sep 6th, 2008 12:13 PM
