This is my first post here and I am in a bit of a crunch. I just replacenmy cylinder head and timing chain because it jumped time on an 09 Mini Cooper S. The engine wont Rev past about 1800 rpm and it surges. The codes I've got are. P0120, P0122, P0222, P0237, P0651, P0107, P012A1, P0113. Any help would greatly be appreciated.
I'm 99% positive that its timed properly and I have checked and rechecked connections. It starts great but it wont Rev up and surges like its in limp mode. Ive also check to see if I pinched a wire somewhere.
That's not good enough, you need to be 100% sure you timed it correctly, did you lock the crank at 90º BTDC and the cams in their relevant position with the camshaft locking tool ?
Performance Powered By Thought. Engineered Horsepower.
I decided to start pulling things apart and there wad a pinched wire that didn't look pinched with everything together. I repaired the wire and now it seems to run great. After I get the rest of the car together and drive it, I'll give an update.
Driving the car, I have a loss of power and I am getting codes 10373 and 10405 on a pegisys scanner. Both of those has to do with turbo pressure but I'm trying to find out now what they are.
