Another misfiring cooper s thread! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 20th, 2012, 03:38 PM
Local Time: 02:12 PM
We have a Cooper S R56 on a 56 plate yes it is the turbo engine, it must be a very early one, it's been misfiring for quite sometime and today I've had a good go over it, I swapped spark plugs and coil packs with another R56. And still the same...
The misfire happens between 1000-1500 rpm and if you accelerate gently then try and hold the revs in this band for a few seconds the car starts to misfire and shakes very violently for about 3 secs then it sort of tries to recover itself, but if you blip the throttle and let it hover back down it does it again, this happens every time and in any gear the real spot to get it to happen worse is about 1100 rpm but as I said it can happen anywhere between 1000-1500rpm.
The car drives fine after this and can pull strong to the red line!
Can anyone help! Please!
Old Sep 23rd, 2012, 05:02 PM
Local Time: 03:12 PM
Hi,
Sound like might be superknock fault, can you read the fault code in DME might say "superknock" can be due to coked engine, there are some threads here which discuss it
The Pies, The Pies
Old Sep 23rd, 2012, 06:31 PM
Thanks for the reply!
I have read about the coked engines, I hope it isn't that! I have read the fault codes on the car but there are no permenant, stored or pending codes there?
Old Oct 12th, 2012, 04:19 PM
Still having this problem!! Tried some bk44g engine cleaner on the last tank full and that's not helped at all, scanned the engine again and still no fault codes.
Tick over can be quite rough when first started and if you hold the revs at 1200 rpm it shudders through the whole car!
Any more help before it gets taken into a mini specialist?
Old Oct 12th, 2012, 04:27 PM
Macguyvic's Avatar
Macguyvic
Local Time: 09:12 AM
United States Male
Sounds like what mine was doing. After a couple of hit and miss attempted repairs it was diagnosed as the high pressure fuel pump. Haven't had the problem since.
Old Oct 12th, 2012, 08:47 PM
I thought about the fuel pump, but I thought it would be loosing power at high rpm's too but its not? Did you replace it yourself or at a garage?
Old Oct 12th, 2012, 09:45 PM
Macguyvic's Avatar
Macguyvic
United States Male
When it ran it was great. Only acted up as you mentioned from a cold start. The dealer first de-coked or cleaned the carbon build up. I took it home and it did the same thing the next morning. Fuel injectors and spark plugs were replaced and 2 days later it did the same thing. It was the third trip to the dealer where they replaced the fuel pump and no issues since then. Knock on wood!
Old Oct 12th, 2012, 09:46 PM
Macguyvic's Avatar
Macguyvic
United States Male
Mine wasn't showing any codes either.
Old Oct 13th, 2012, 11:15 PM
United-Kingdom
I have a 2007 cooper s and i was getting similar problems, i thought my engine was coked up, i used BG44K a few times, was a little better but still persisted. So after much searching on the internet (as you do!) i decided to try the simpler option of better fuel.I started to fill up with shell v power which is 99 RON unlike normal unleaded which is 95 RON, and the results are amazing my car is transformed, the only thing i can suggest is the that the s does not like cheap fuel, higher octane fuel works a dream in my car, would not go back to normal unleaded ever. Give it a try......
Old Oct 14th, 2012, 06:39 AM
MCS-W11NJP
My 07 cooper s runs ok its got 45k on the clock. Only thing I can add is like the above poster has said. Try running on super unleaded, a slightly cheaper form of 99 RON fuel is Tesco momentum. I was told to use it by a tuning garage in Essex when they worked on my Fiesta ST.
Make sure you let your tank get as slow as you feel comfortable with before filling up, less dilution of the new fuel with the old fuel and stops any build up of crud at the bottom of the fuel tank. Use 3/4 even 5 tanks of 99 RON fuel and come back and see if it has solved it.
Old Oct 19th, 2012, 12:17 AM
pull the intake back and see if you have carbon build up on the back of the valves. if you do clean it out with a pick and some brakleen. if you can check you fuel pressure after the high pressure fuel pump it should be over 5bar. if its not its your pump, but im pretty sure that a faulty pump will store faults.
AND THIS IS FOR EVERYONE ELSE READING THIS. 1. R56 S UP TO 2012 HAVE DIRECT INJECTION WITH A POOR OIL DELIVERY SYSTEM, 2012 HAVE IMPROVED OIL SYSTEM. THAT MEANS THE FUEL DOES NOT SPRAY THE BACK OF YOUR VALVES AND DOES NOT WASH THE OIL OFF. AND THAT MEANS THAT USING ANY KIND OF INJECTOR CLEANER TO CLEAN YOUR VALVES WILL NOT DO ANYTHING FOR THE BACK OF YOUR VALVES. TO PREVENT THE CARBON BUIDL UP DRIVE YOUR CAR HARD FROM TIME TO TIME. THAT MEANS READLINING IT.
