| Mini tech needs halp from other mini techs Hi im new to this forum and not sure how all of this works. so if this problem was brought up before i apologize. anyway i have a r56 n12 around 11k miles with a 2789 fault code (lean) and i was wondering if any techs on here have seen it before. some of the things i have done. checked the spark plugs and coils. no problem found. smoked the intake components. no problem found. smoked the vacuum pump. no problem found. smoked the brake booster (have had the same fault in a different car and it ended up being a cracked brake booster) no problem found. i would check the injectors and the timing but at 11k i dont think there will be a problem with them. any ideas????? |
