key fob wont start car! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 17th, 2012, 03:05 PM
Local Time: 05:39 AM
PLEASE HELP! iv been having trouble with my key fob not locking door for few days now. That seems to be ok now...but this morning i put the fob in my 07 reg diesel mini cooper and nothing! No lights no ignition nothing! The fob still locks and unlocks car though! Please help as only have this one fob so cant use my car even to get to a garage! Could this be a fault with the fob or car?
Old Nov 17th, 2012, 05:20 PM
Local Time: 06:39 AM
Is the actual car battery ok? all sorts of problems are created if the battery voltage drops below a certain point?
Old Nov 18th, 2012, 07:58 AM
Local Time: 04:39 PM
Australia View POV04's Lightning Blue & Black 2nd Gen MINI John Cooper Works Profile
Also you may need to replace the battery in the Key Fob itself. There maybe enough power to unlock/lock door but not enough to activate when the ignition when the ignition is active.
Do you have a second key fob unit? Have you tried that one, is the fault there with that key fob?
Old Nov 18th, 2012, 08:40 AM
Havnt checked battery so not sure but the radio works on its own. Havnt got a spare fob thats the only key iv got
Old Nov 18th, 2012, 09:20 AM
The radio would work until the battery gets very low though,
Give the battery a charge for an hour or so, then try it? but I know you will say you havent got a charger?
Trouble is these days everyone becomes so used to not having to do anything to the car all the old get you going skills are lost.
Old Nov 18th, 2012, 09:23 AM
From a previous post:
the key stopped working,
tried the above ,to reset the key, and it worked perfectly, so a huge great thankyou to designer-label for the cure, i thought i might have to take a day off to take the car into the city to the BM dealer,plus the cost, i'm now a very happy bunny.
To reset your key, well for 2004+ versions this works not sure if older ones...
Get in MINI put key in ignition then take it out
Point key at aerial at back of car
press and hold UNLOCK button
press key LOCK button 3 times within 10 seconds WHILE keeping UNLOCK button depressed.
Release UNLOCK button
System should lock and unlock car to indicate programming has been successful.
Old Nov 18th, 2012, 02:06 PM
I have changed the battery still no joy even tho wen the old battery was tested was very low. Was hopeful that was the problem but the fob still not starting it andthe aarms are set off when the doors unlocked?! Still confused. Tried reseting ittoo
Old Nov 18th, 2012, 04:16 PM
Im not so sure, but when resetting the key you have to be? in the car with the doors closed throughout the procedure, do you do it that way?
Give that a try.
Oh one other you could try recharging the key as its battery now might be flat, if you have an electric toothbrush, the holder has a induction loop charging system for the brush, lay the key on the holder switch it on and leave it for an hour or so to fully recharge??
