Engine light (O2 sensor code) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 28th, 2013, 06:12 PM
Local Time: 11:14 PM
Engine warning light came on last week however mini (07) is running really well. Code P2626 (O2 Sensor Pumping Current Trim Circuit/Open). Garage replaced the O2 sensor (bosche). Ten days later the light came back on with the same code.
Taking into consideration the mini is running really well and it's just had a new O2 sensor any advice would be welcome..........
Thanks.
Old Feb 2nd, 2013, 06:50 AM
Cyprus Male
You probably have condensation on the connector. They made the stupid mistake of positioning the connector vertically, next to the oil dipstick. So water can get through the wires in the connector. Open it and clean it with WD40 (it displaces water) and see if it helps. I think for the light to go away you need to start and shut down the car a couple of times. If you have a scantool then just delete it and see if it comes back.
Old Feb 2nd, 2013, 03:37 PM
Thanks.
Thanks I'll give it a try tomorrow . I just changed the air filter but sadly the light is still on! *Mini is booked into main dealer on Tuesday but would love to try and fix the problem myself.Thanks again................
