Grrrrr. R56 Help please. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 28th, 2013, 10:02 PM
Local Time: 08:50 PM
Angry Grrrrr. R56 Help please.
Hello Fellow Mini Owners.
Iv had my car a while now and to be honest i loved it. Im starting to get a bit annoyed with it now with little problems arising.
1. I had a new battery on the car and no when i unlock my cars the boot doesn't open. Before i could unlock my car and the passenger and driver door would open also my boot would so i could just press the button on the boot and it would open.
Now this doesn't happen and i have to press the boot button on my fob. Can anyone help?
2. I have a slight squeak in the engine? Loose fan belt or alternator belt??
3. When i press the button to open my window both, passenger and driver side will fully open. Although when i press the button up for the same to happen fully shut. only the driver side will. I have to hold the passenger side button up for it to shut fully.. Would i need to reprogram or is some broke??
Other than i still want to make alterations to my car and make it look even better than what it does now. But i don't wanna spend money on cosmetics and increasing BHP if small problems are going to cost me money. Any information and help would be appreciated so much......
Old Jan 28th, 2013, 10:13 PM
Macguyvic's Avatar
Macguyvic
Online
Local Time: 02:50 PM
United States Male
I am jumping to number 2. I had an intermittent squeal that was caused by the water pump which was replaced. Both water pumps were replaced but I think it is the main water pump that was squealing.
Once you roll up the passenger side window continue to hold the switch in the up position for a few seconds, which should reset the auto up.
Old Jan 29th, 2013, 05:02 PM
Excellent, i will try the window setting now. Also just wanted some reassurance it was the water pump.
Old Jan 29th, 2013, 05:10 PM
No just tried holding window button up and nothing. any other ideas?
Old Jan 29th, 2013, 06:06 PM
Regarding the window i dont think passenger window goes up with one touch like the drivers one does, mine never has. [april 2006 mini cooper]
Old Jan 29th, 2013, 07:49 PM
Local Time: 07:50 PM
I have a 2007 R56 MCS and my windows are exactly the same. Drivers goes up with a flick but passenger one needs to be pushed the whole time.
Old Jan 29th, 2013, 08:43 PM
United Kingdom Female
I've got a 2009 R56 and both my windows go up fully with one touch. The only thing is that I do them individually. I'll tap the up on one window and immediately do the same on the other so they both go up automatically. If I try to be clever and do both up at exactly the same time, I inevitably mess one up and have to do them individually anyway. But that's 'cos I use one hand. Fingers not long enough to reach both switches properly. :-)
Old Jan 29th, 2013, 08:50 PM
57 MCS here .. passenger window switch has to be held all the time for it to go up. Only the driver side is 1 touch.
Old Jan 29th, 2013, 09:59 PM
2009 MCS both windows work with 1 touch - Wifes 2012 one also works one touch with both windows.
Old Feb 9th, 2013, 04:03 AM
Local Time: 06:50 AM
Australia
Q1 is a setting in the personalisation car setting on the BC stalk - check your manual.
Tags: , ,
