Please help!
Recently I have noticed condensation/ice on the inside of the windscreen. I later noticed that my passenger car may was soaking wet, right through to the carpet underneath.
I have a small puddle in the rear passenger footwell. Only the carpets are wet, none of the plastics or upholstery.
I later noticed that the passenger window comes down when the door is opened, but it no longer goes up automatically, it can be done manually from the inside and still goes up and down as normal.
I have been quoted £365 for the motor part for the window! Is that correct; without labour to fit it? Will that also fix my leaky problem- I assume that the water has been coming in through the 1cm gap as the window hasn't closed itself
Thank you
