Breathing/fueling/rad fan problem??? 2009 JCW - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Faults & Fixes > Second Generation Faults & Fixes
New owner of 2009 MINI JCW Hardtop marcopolo07 Welcome New Members 2 Jan 4th, 2014 09:01 AM
2003 r53 fan problem.. Will.i.am First Generation Faults & Fixes 0 Mar 5th, 2013 05:30 PM
Not sure between a 2013 JCW mini with a ECU upgrade or a very tuned 2009 MCS. MiniPhx General Discussion 3 Dec 30th, 2012 07:18 PM
Old Jan 3rd, 2014, 10:04 AM
JamesTeehan
Local Time: 04:14 AM
Hi guys,
Can anybody shed any light on this problem??
I've got a late 2009 factory JCW and this problem started intermittently about 6 months ago but now seems to be permanent!
Symptoms are:
Jerky acceleration (hold throttle in steady position, yet feels as though you're opening and closing very quickly)
Induction noise has changed for the worse. Sounds louder than usual and just generally like it's poorly, doesn't seem to be the exhaust though.
The "pops" you get on the overrun have changed from the usual single pop to several pops
Power is down quite dramatically - feels strangled
Radiator fan often comes on, even after doing a very short journey, and stays on after turning the engine off. Impossible that it's had the chance to get warm, let alone too hot.
I actually had it serviced straight after the problem started and the garage said it was the plugs - which I had sorted.
Just had a look at the air filter to see if that was okay, and it seems fine. No sign of blockages or anything simple.
Any help would of course be appreciated, as I want to put the car up for sale this month (sadly :-( company car has now arrived and the mini is in the way :-( :-( :-( )
James
Old Jan 3rd, 2014, 12:30 PM
Hi ya
I would say you need to get it hooked up to a diagnostic computers and see what the codes are first
I have seen similar problem caused by something simply like a water temp switch and also bad fuel pump.
I think there is a tsb for the temp switch for internal corrosion
high pressure fuel pump are a known problem area.
But before rushing in I would get it connected up to a computer first save your self a lot of time and money.
Have you had all your latest recalls done on you fjcw
Hope this help
Old Jan 3rd, 2014, 11:18 PM
JamesTeehan
Thanks for the reply buddy, I really appreciate it. I'll get it looked at ASAP.
These recalls you mention, sorry to sound like a total prat but could you elaborate? Is this something I should contact mini on?
Old Feb 7th, 2014, 10:10 PM
JamesTeehan
Just so not to leave this unresolved. Finally got the car back today. Turned out to be a faulty thermostat. Stuck open.
For the sake of other users here's a list of symptoms.
- Power loss noticeable over 3000 rpm
- high fuel consumption
- climate control (heating) starting from cold straight away rather than waiting until warm
- change in the sound of the pops you get on overrun.
- radiator fan staying on after ignition switched off, even after short journeys
All of these symptoms were intermittent for about 10k miles or 6 months.
The job cost 190 + VAT plus 50 for diagnostics. That also included resetting service indicator which the garage who serviced the car last "couldn't do".
All sorted now. Running perfectly.
Hope this helps others.
James
» Recent Threads
Will I get jipped?
Yesterday 11:14 PM
Last post by whaap
Today 03:03 AM
2 Replies, 77 Views
2015 Roadster S Backup Light(s)?
Oct 11th, 2014 12:19 PM
Last post by StarFlyr
Today 01:06 AM
1 Replies, 359 Views
Anyone rented Mini to drive around Europe?
Jun 25th, 2011 01:55 PM
by MarkLaw
Last post by chistacha2
Today 12:24 AM
7 Replies, 1,824 Views
2001 Cooper wheel nut key
Oct 20th, 2014 05:05 PM
Last post by Caveman
Yesterday 10:51 PM
4 Replies, 325 Views
Lights on warning not working
Yesterday 11:42 AM
by S2dicky
Last post by S2dicky
Yesterday 10:32 PM
1 Replies, 149 Views
R56 Aux input volume???????
Oct 20th, 2014 04:00 PM
Last post by peteski2014
Yesterday 09:04 PM
2 Replies, 271 Views
New iPhone update messed up blue tooth, anyone else?!
Oct 20th, 2014 02:35 PM
Last post by chris0074
Yesterday 08:31 PM
5 Replies, 316 Views
Fuel Consumption in Mini Cooper D 2014
Yesterday 08:09 PM
Yesterday 08:13 PM
1 Replies, 115 Views
Start/Stop engine button illuminated when car is locked
Yesterday 08:07 PM
Yesterday 08:07 PM
0 Replies, 106 Views
Build up of rain water...
Yesterday 05:15 PM
Yesterday 07:35 PM
2 Replies, 137 Views
PAS Fluid Leak HELP!!
Oct 15th, 2014 07:16 PM
Last post by JollyRotten
Yesterday 06:14 PM
6 Replies, 517 Views
speed displayed on tachometer is a little bit higher than actual speed! Help!
Yesterday 06:45 AM
by tianfa1
Last post by Angib
Yesterday 05:58 PM
4 Replies, 249 Views
LED Side Lights
Oct 16th, 2014 10:34 PM
Last post by mab01uk
Yesterday 05:49 PM
4 Replies, 474 Views
Misfiring R55 JCW engine in 6th gear between 2k-3k RPM with throttle wide open
Yesterday 10:30 AM
Last post by Mr Muffin
Yesterday 04:33 PM
6 Replies, 356 Views
UK Big Brake fitment, what to do?
Oct 20th, 2014 01:44 PM
Last post by ihughes
Yesterday 03:55 PM
1 Replies, 284 Views
Rear wiper motor stem problem
Oct 18th, 2014 09:57 AM
Yesterday 03:48 PM
2 Replies, 370 Views
Strange Noise
Oct 16th, 2014 10:28 PM
Last post by CCroker
Yesterday 02:20 PM
2 Replies, 304 Views
Mini Cooper with Helicopter Turbine Jet Engine
Feb 29th, 2012 05:36 PM
by mab01uk
Last post by Aliraza852
Yesterday 12:10 PM
5 Replies, 1,462 Views
JCW intercooler intake grille.
Oct 19th, 2014 08:06 PM
Last post by The Nun
Yesterday 08:31 AM
3 Replies, 363 Views
Automatic transmission - settle a bet!
Oct 18th, 2014 06:05 PM
Last post by whaap
Oct 20th, 2014 11:49 PM
8 Replies, 634 Views
Wheel & Tire Center
