Fault codes - MINI Cooper Forum
post #1 of 2 (permalink) Old Jan 4th, 2014, 01:12 PM Thread Starter
Local Time: 10:31 AM
Fault codes
My son has got the following 2 fault codes on his 2007 Mini One
278A Catalytic converter conversion rate
Faulty
2B68 Intake-manifold pressure
Value too low
How serious is this and any idea how much it might cost to fix?
spearos is offline
post #2 of 2 (permalink) Old Jan 5th, 2014, 12:35 AM
...opinionated!
Deep_27a's Avatar
Local Time: 11:31 AM
United Kingdom Male View Deep_27a's  &  2nd Gen  Profile View Deep_27a's Classified Ads
Faulty
Value too low
Im not savvy with all of this but googling your fault codes indicates whatever is causing fault code 278A could result in incorrect readings in the intake manifold sensor which is causing your second fault code (2B68)...
Deep_27a is offline
Help! Dashboard lights going crazy! daniel.w.leigh Second Generation Faults & Fixes 10 Oct 27th, 2015 06:03 PM
R53 SRS airbag light and fault codes kirby First Generation Interior & Ice 0 Apr 28th, 2013 08:25 AM
Ubiquitous airbag fault - tracing actual problem tieak First Generation MINI One 2 Apr 24th, 2013 10:57 AM
R56 Cooper S fault codes/ no boost das882 Welcome New Members 3 Mar 27th, 2013 09:45 AM
Fault codes on my mini james13009 First Generation Faults & Fixes 1 Dec 19th, 2012 03:37 PM
