R58 Electrical or Brake problem? - MINI Cooper Forum
post #1 of 2 (permalink) Old Jan 7th, 2014, 11:22 AM Thread Starter
Local Time: 01:04 PM
Sweden
New to this forum so thanks for any help!
My 2012 R58 S (30k miles) has the lift light come on when starting then the brake light never goes off.
I am assuming it needs brake pads/sensors, all around? But have also read here and in manual that it is an electrical problem?
If I do put sensors/pads on do I need to reset so lights go off/then how?
Great to be a part of this...pushed to this because they want nearly $1000 to do brake pads here in Sweden!
Topform
topform is offline
post #2 of 2 (permalink) Old Jan 7th, 2014, 01:58 PM
Local Time: 12:04 PM
Quoted: 40 Post(s)
The service display in the tacho will tell you if the warning if for front or rear brakes - they are monitored separately.
The brake wear sensor is triggered fairly early, so if you want to save money, you can take off the wheels and check the pad thickness by eye and continue to drive the car until they are worn down.
You may need new discs as well as pads - approximately, discs are needed every two sets of pads.
As the wear sensor has been triggered, you will need a new one of those too.
Front brake change sheets are attached, but I don't have the rear ones. It is all very easy to do yourself if you have the tools.
The service warning can be reset 'manually' (without a computer), but I have forgotten how - hopefully someone else will say.
File Type: pdf RA Removing and installing or replacing both front brake discs.pdf (31.9 KB, 37 views)
File Type: pdf RA Removing and installing_replacing brake pads on both front disc brakes.pdf (106.2 KB, 71 views)
File Type: pdf RA Replacing a front brake pad sensor.pdf (32.6 KB, 55 views)
Angib is offline
The Following 2 Users Say Thank You to Angib For This Useful Post:
Tags: , , , ,
New Mini 2013 - brake problem and rejecting it chloek1990 Second Generation Faults & Fixes 3 Mar 20th, 2015 05:37 PM
Brake Problem? Kalenshah First Generation Faults & Fixes 0 May 1st, 2013 08:17 AM
2003 mini cooper electrical problem gauges dont work SafetyMoose First Generation MINI Cooper 0 Jan 17th, 2013 06:39 PM
front jcw brake caliper bracket problem morgi27 Wheels, Tyres & Brakes 2 Oct 11th, 2012 08:54 PM
Weird Starting Problem - Electrical, Lock or Computer Maybe? Mrelia First Generation Faults & Fixes 4 Aug 18th, 2012 02:46 PM
