Blower controls - MINI Cooper Forum
post #1 of 8 (permalink) Old Jan 25th, 2014, 01:36 PM Thread Starter
Local Time: 06:12 AM
Blower controls
Hi,
has anyone had issues with the internal blower running at Max only? Ive got a set switches of ebay but that didn't cure it.
my thoughts are now turning to the blower itself.
Andy
andykb is offline
post #2 of 8 (permalink) Old May 4th, 2014, 10:57 AM
Hello Andy,
couple of day ago I got the same problem. Have you found out the reason?
Best regards
werd37 is offline
post #3 of 8 (permalink) Old May 4th, 2014, 01:33 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Failure of the low speed motor resistor
Guide to fix on: TotalMini (dot) com
Add a dot as links to totalMini not allowed on Mini2......
I lost all fan speeds except flat out on my R56 Dooper (with manual heating controls).
I suspected this was a failure of the low speed motor resistor(s) and set about finding where it was. This jobs turned out to be very simple so thought I would add this guide for anyone with the same problem:
http://www.totalmini(dot) com/forum/18-2006-2014-2nd-generation/7995-replacing-faulty-resistor-pack-heater-blower.html
mab01uk is offline
post #4 of 8 (permalink) Old May 4th, 2014, 01:47 PM
Thanks a lot. Just before your answer I checked the resistor (took some time to find it without knowing), it is really dead.
werd37 is offline
post #5 of 8 (permalink) Old Jun 11th, 2014, 07:09 PM
Local Time: 07:12 AM
Blower motor resistors are a common fault that will leave the blower only operable on max setting. The resistor is located on the side of the heater matrix in the passenger side footwell. They are not difficult to remove and replace.
BMWazza is offline
post #6 of 8 (permalink) Old Jul 23rd, 2014, 07:50 PM
Damned
Restyle's Avatar
Quoted: 4 Post(s)
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
Originally Posted by mab01uk View Post
Failure of the low speed motor resistor...
Looks like the resistor failed on my 2004 MCS today - Fan now just works on positions 3 & 4!
Whereabouts would be the location of mine? & I dont suppose you have the circuit diagram with resistor values involved? The diagram on the totalmini link seems a bit obscurred
Restyle is offline
post #7 of 8 (permalink) Old Sep 20th, 2014, 04:48 PM
United-Kingdom
on my daughters of 05 UK model, the resistor pack is at the back of the right hand (drivers side on RHD) foot well mounted on the fan complex. Requires you to remove 1 x T20 screw holding the resistor pack in place. has 4 wires leading to it (red, blach, blue, and black & yellow). A bit fiddly, but only takes about 15 mins to complete.
bobscu is offline
post #8 of 8 (permalink) Old Sep 20th, 2014, 08:49 PM
Damned
Restyle's Avatar
Quoted: 4 Post(s)
Originally Posted by bobscu View Post
.... the resistor pack is at the back of the right hand (drivers side on RHD) foot well mounted on the fan complex....
I had mine replaced by a local MINI breaker.
When looking at the 'resistor' pack, I noticed it wasn't a resistor at all but a voltage regulator circuit -which delivered different set voltages for each fan speed.
Explains why it costs so much I suppose.
Restyle is offline
Mini 2006 - First Gen - Stereo System / Bluetooth / Controls holycow General Discussion 0 Jul 13th, 2013 06:12 PM
Airbag Light on radio and blower doesn't work dshishman First Generation Faults & Fixes 5 Feb 21st, 2013 04:23 AM
Cooper Diesel Steering Wheel Controls Bonxy MINI Cooper Diesel 2 Dec 16th, 2012 10:21 AM
steering wheel controls barmyarmy1966 Second Generation Interior & Ice 2 Nov 14th, 2012 04:42 PM
Fitting a Parrot MKi9200 with steering wheel controls pukmeister Second Generation Interior & Ice 0 Aug 25th, 2012 11:00 AM
