06 Mini Cooper S Turbo no boost? - MINI Cooper Forum
post #1 of 2 (permalink) Old Jan 28th, 2014, 03:52 PM Thread Starter
Local Time: 05:57 PM
United States Male
DIY 06 Mini Cooper S Turbo no boost?
ITs a 07 mini cooper s turbo charged not a 06 sorry. I scanned the car for codes with a generic code reader, and these are the codes Im getting and what they mean according to mini code's, 2nd gen..
P0507- Engine speed too high. IAC system higher then expected.
P1497- Downstream Throttle Air leak
P2177- Fuel trim limit exceeded. System Too lean
Now the car feels like the turbo is not spooling at all. I mean no power what so ever but you do hear a small spool like 1/2 psi and blows off very faint (removed the silencer if that helps). I'm guessing the down stream air leak is the culprit on lost of power and probably throwing the fuel trim off as well. Now what I'm trying to locate Is, what pipe or from what point is the down stream air leak located standing in front of the car or where should I be checking for that? The car also 'hunts' for idle sometimes, It will hold at 2k go back down to idle go 2500k, back to idle from time to time.
Mini4Life06 is offline
post #2 of 2 (permalink) Old Jan 28th, 2014, 04:31 PM Thread Starter
United States Male
Also getting that hissing noise from the P/S near the valve cover on that intake hose the smaller one that leads to the valve cover. Iv searched online and it says it can possibly be a cracked valve cover. The car has 115k if that matters in this situation...
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 06:11 PM
Forge Uprated Alloy Intercooler for Mini Cooper S Turbo fcminicoopers Second Generation MINI Tuning 4 Mar 25th, 2013 02:44 PM
Forge - Blow Off Adaptor For BMW Mini Cooper S Turbo UtilityGuy Second Generation MINI Tuning 1 Jan 21st, 2013 07:17 AM
2008 R56 Mini Cooper S Turbo! RGJACOBSON Welcome New Members 0 Dec 26th, 2012 12:48 AM
