2011 Countryman S no power at 4,000rpm HELP - MINI Cooper Forum
post #1 of 3 (permalink) Old Jan 28th, 2014, 10:16 PM Thread Starter
Local Time: 11:06 AM
I have seen multiple threads about loss of power in these cars with random problems. I am hoping that some one can point me in the right direction here. I have a 2011 Countryman s with 70K miles. Bought it used a month ago. I think the former owner did not take care of it as he should. Here is the story-
Ran great the first week we had it. On a long road trip we stop for gas ( always using premium) the yellow engine flickered on and back off. Adjust the gas cap and went on with our trip. While visiting we had a bunch of codes pop up and it ran like crap. Random missfires and low fuel pressure. The turbo also stopped kicking in. (I thought that may be from the engine warning light) Found the HPFP to be a common problem and cause this so I replaced it.
Since then it has had random feeling of missfire but no codes. I have replaced all the coils and the plugs. Car randomly seems to have turbo and then not. Jerky like a missfire. Finally a code popped up and it said miss fire on p300. So I double checked the pugs and coils and all seem well. checked all connections and looked for leaks. Took it for a test drive and here is what I experienced after clearing codes.
In first gear the tach got to 4,000 and the motor had no juice. Not really a miss but no power. No turbo wind up either or even a sound.
Second Gear and third the exact same thing except in third felt like maybe a miss starting. I did not push any more. No codes at all.
Please help
Hizapitt is offline
post #2 of 3 (permalink) Old Jan 29th, 2014, 10:42 AM
Local Time: 05:06 PM
Sounds like your engine is not receiving the turbo boost. You have replaced the spark plugs and coil and the problem exist therefore it suggest to me the Turbo Boost Valve or the inlet manifold (or sensor) is misbehaving. Since your countrymen is still under warranty take it to Mini and let them deal with it.
ozmusafir is offline
post #3 of 3 (permalink) Old Feb 4th, 2014, 09:06 AM
Local Time: 04:06 PM
I hi have a countryman sd 2013,had it back in shop for same problems,replaced turbo unit twice, part of a wireing harness,and now has just lost power again,back in garage,wish i never seen car its nothing but trouble.
deanfowler is offline
Radio Boost CD Display 2011 Mini Countryman Terri2 Third Generation Interior & Ice 1 Jan 17th, 2017 05:29 PM
2011 mini countryman error code paceman007 Second Generation Faults & Fixes 1 Dec 1st, 2013 11:37 PM
Motortrend's 2011 Countryman S ALL4 Slushbox Verdict Blackhawks MINI Countryman 2 Dec 15th, 2012 10:35 PM
Automobile Magazine's Wrap-up of 2011 Mini Countryman S ALL4 Blackhawks MINI Countryman 5 Nov 26th, 2012 05:35 AM
