Cooper S battery - MINI Cooper Forum
post #1 of 10 (permalink) Old Jan 29th, 2014, 08:08 PM Thread Starter
Local Time: 07:44 AM
Cooper S battery
Just wondering if anyone can help with an issue I've got with my battery, basically it's at the end of its life and the car is struggling to start occasionally. Just want to know if I could use a 12v 45ah when I've got a 12v 55ah fitted? And what's the difference between? Thanks in advance.
logan_manc is offline
post #2 of 10 (permalink) Old Jan 29th, 2014, 08:21 PM Thread Starter
Just realised I put this in the wrong section, I was meant to put it in the first generation Cooper S section.
post #3 of 10 (permalink) Old Jan 29th, 2014, 08:23 PM
mab01uk's Avatar
Quoted: 1 Post(s)
As the AH (Amps/Hour) rating increase car batteries tend to get larger/heavier so if a battery fits the space available there is no harm fitting a higher AH rating battery. However it is not advisable to fit a smaller AH battery than that specified by the car manufacturer, a Mini One will probably have a lower AH battery than say a Mjni Cooper S as the higher model will usually make more demands on the battery for cranking the engine over and powering more electrical options fitted as standard, etc.
eg. A battery with a capacity of 1 amp-hour should be able to continuously supply a current of 1 amp to a load for exactly 1 hour, or 2 amps for 1/2 hour, or 1/3 amp for 3 hours, etc., before becoming completely discharged.
mab01uk is offline
post #4 of 10 (permalink) Old Jan 29th, 2014, 08:29 PM Thread Starter
Cheers for the reply, so you'd recommend me using the same size battery? 12v 55ah
post #5 of 10 (permalink) Old Jan 29th, 2014, 08:44 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Yes.....the 45AH will work but will reduce the safety factor, it may also struggle under certain conditions especially as it gets older and like say on a cold morning start up with heated windows, headlights and power steering pump, etc all working hard. Modern cars like the Mini make a lot of electrical demands on the battery even under normal running conditions.
mab01uk is offline
post #6 of 10 (permalink) Old Jan 30th, 2014, 02:00 PM
Quoted: 24 Post(s)
If you are looking to replace the battery in a Gen 1 Cooper S, do make sure you are purchasing the correct size (dimension) battery as I found out from the RAC that many of the motor factors have the wrong battery listed for the Gen 1 Cooper S Mini.
When I used the RAC to supply and fit a replacement battery for my Cooper S I ordered it online supposedly using the car registration number to identify my vehicle, but when the fitter arrived to instal at my home he actually brought the battery I had ordered and the correct one for the car which is physically larger (and more expensive) than the one listed on-line.
If you get the wrong size battery the retaining clamp will not secure the battery in the boot!
In the end everything was fine with the correct battery, and they didn't charge me for the extra cost that I should have paid.
Spike
ihughes is offline
post #7 of 10 (permalink) Old Jan 30th, 2014, 05:05 PM Thread Starter
^^^ just found this out when I phoned my local car parts place, they told me there is 5 different sizes for the Cooper S between 2001-2005. Nightmare or what, I wouldn't mind but I work with cars everyday so I shouldn't have to be asking questions haha
post #8 of 10 (permalink) Old Jan 30th, 2014, 05:27 PM
Caveman's Avatar
Local Time: 09:44 AM
Quoted: 83 Post(s)
Why not measure the dimensions of your battery and compare it to what is available?
Caveman is offline
post #9 of 10 (permalink) Old Feb 5th, 2014, 10:53 AM
Local Time: 08:44 AM
Cyprus Male
The sizes and types are standardized. The MINI uses the german DIN system (easily identifiable as the battery has handles to lift and place). I think it should be about 28cm in length (not 30+) and about 18cm or less in height. As for the rating, go for at least the 55Ah indicated or higher. Bosch has catalogs detailing all battery dimensions and capacities online which can help you with your selection. Korean manufacturers also offer DIN batteries for similar ratings in a smaller size.
But measure yours to be sure, as I am writing out of memory and I have a 2nd gen.
alexcannas is offline
post #10 of 10 (permalink) Old Feb 5th, 2014, 08:51 PM
Damned
Restyle's Avatar
Quoted: 4 Post(s)
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
See chart HERE for all Car/Van battery sizes & number codes
Restyle is offline
Battery drain problem hoggy1972 First Generation MINI Cooper 5 Feb 5th, 2014 04:25 PM
Mini Cooper S (Petrol) 2010 Battery Charging Courtneybanks General Discussion 2 Dec 31st, 2013 01:04 PM
Cooper not starting, flat battery? READ ON colinthecooper First Generation Faults & Fixes 3 Mar 20th, 2013 12:32 AM
Battery change 2008 Cooper odderz General Discussion 0 Nov 25th, 2012 05:20 PM
2004 Mini Cooper Fob Battery dead atraain General Discussion 7 Sep 12th, 2012 09:41 PM
