R56 Cooper S will not start - MINI Cooper Forum
post #1 of 1 (permalink) Old Feb 12th, 2014, 05:39 AM Thread Starter
Local Time: 09:40 AM
Yesterday my car wouldn't start in 24F degree weather. When I try to start it, it tries to start up normally, and I can hear it turning and cranking (barely), but it doesn't start.
After lifting the hood, I noticed that ice and snow got on the battery, literary connecting the + and the -. This is because I'm missing the battery cover. I removed the ice. I thought it was a weak battery, so I charged up the battery and tried to jump it, but it still wouldn't start.
Can someone help me!
Right now, I'm thinking it's either a fuse burned (from the ice between the + and -), the fuel line froze(from below freezing temperatue), or the fuel pump broke (from the cold?). I put regular (89) gas in the car, it's an automatic, 2007 R56 Cooper S with ~35K miles. It last started a couple days earlier, but it was just started and sat idle for about an hour while removing the snow. I checked with an ODB reader, no error codes.
I tried to check the fuse box inside the car, but those fuses are impossible to pull out! Am I supposed to use a special tool? The freezing weather doesn't help!
xtwister161 is offline
R56 Mini Cooper Erratic surging at idle from cold start Norfolk-Mini Second Generation Faults & Fixes 7 Mar 23rd, 2016 02:42 AM
True running costs of R56 Cooper S? cupofjavaa General Discussion 8 Nov 23rd, 2013 08:25 AM
Does r56 cooper S front bumper fit r56 cooper? irfan.s Second Generation MINI Cooper 0 Feb 14th, 2013 11:22 AM
Mini Cooper S R56 Black smoke on cold start daz4805 Second Generation Faults & Fixes 4 Oct 4th, 2012 09:20 AM
'07 cooper s wont start after loose tensioner. Timing? geekycraig Maintenance & MINI Care 0 Oct 3rd, 2012 07:03 PM
