2005 JCW intermittent clutch problem - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Faults & Fixes > Second Generation Faults & Fixes
Intermittent sound problem with IPOD and AUX inputs dsmith Second Generation Interior & Ice 3 Jan 22nd, 2014 08:30 AM
2003 seats in 2005 airbag problem Blackwhite First Generation Interior & Ice 4 Nov 23rd, 2013 08:12 AM
Intermittent Oil Warning Light Problem andyjshaw Second Generation MINI Cooper S 6 Jul 8th, 2013 09:57 PM
odd clutch problem stevegosfield Second Generation Faults & Fixes 2 Dec 27th, 2012 07:17 PM
2005 JCW Electronic Problems daveyroy61 Welcome New Members 0 Oct 9th, 2012 05:42 PM
Old Feb 16th, 2014, 05:08 AM
05 MINI COOPER S JCW
Local Time: 11:15 PM
United States Male
DIY 2005 JCW intermittent clutch problem
hi guys I have a 05 JCW with a intermittent clutch problem. Sometimes it wont go into gear but if I let it sit for a few seconds it will go into gear. I think its the slave because I didn't see any leaks from the master cylinder or could it be something else. The car doesn't make any weird noises or rattles and when the gears decide to work it works fine and the clutch too. Please Help Thanks!!!
ID:	169273   Click image for larger version
Old Feb 20th, 2014, 10:07 AM
Local Time: 01:15 AM
Luxembourg Male
Couple of things come to mind. First check the hydraulic fluid level, if it's between min and max, it's likely unrelated to the slave/master and your prospects are less optimistic. What's the clutch pedal feel like?
Sounds to me like the clutch is dragging, but the difficulty shifting into gear could also be due to worn synchronizers.
Other issues could be bad pilot bearing, misalignment of transmission housing (i.e. bad motor mount) or bad clutch release mechanism.
I'd take it to a shop for further diagnosis.
» Recent Threads
Trying to figure out where the last connector goes???
Today 10:28 PM
by Eirhead
Last post by Eirhead
Today 10:28 PM
0 Replies, 9 Views
Timing chain tensioner upgrade?
Yesterday 11:05 PM
by ben2012
Last post by ben2012
Today 09:51 PM
1 Replies, 180 Views
New member seeking advice!!
Today 07:50 PM
by Buick7
Last post by Buick7
Today 07:50 PM
0 Replies, 74 Views
speed sensor
Today 06:52 PM
Last post by Goofeyrider
Today 06:52 PM
0 Replies, 65 Views
Cooper EML very odd!
Today 05:33 PM
by maffup
Last post by maffup
Today 05:33 PM
0 Replies, 114 Views
heat problem
Aug 24th, 2014 10:04 AM
Last post by mab01uk
Today 04:24 PM
8 Replies, 551 Views
Need opinions. do I join the Mini family or the VW family.
Today 10:17 AM
by jnapier
Today 04:17 PM
1 Replies, 201 Views
Brake light with car on lift indicated.
Today 02:01 PM
Last post by stexasmini1
Today 02:01 PM
0 Replies, 117 Views
Can't post in Classifieds
Yesterday 07:47 AM
by Jonny_5
Last post by Jonny_5
Today 12:19 PM
4 Replies, 402 Views
how to extinguish brake wear warning light
Today 01:44 AM
Last post by cristo
Today 12:17 PM
3 Replies, 261 Views
Blanking plug for AUX install
Aug 6th, 2014 09:55 AM
Last post by excession
Today 11:11 AM
2 Replies, 482 Views
PAssenger Door won't open from inside using the handle
Aug 9th, 2014 09:13 PM
Last post by The Nun
Today 09:10 AM
2 Replies, 405 Views
Powe steering pump fan
Yesterday 05:42 PM
Today 07:29 AM
3 Replies, 273 Views
What do you think of this mini? And a couple questions...
Jul 12th, 2014 08:44 AM
Last post by Moonwalker09
Today 01:04 AM
4 Replies, 930 Views
My New Mini MCS
Mar 22nd, 2013 11:15 PM
by mossyS
Last post by KarenTMonn
Yesterday 11:50 PM
6 Replies, 2,879 Views
TWINI - Twin engine R53 Endurance Race Car
Jul 18th, 2013 08:30 PM
by pooper
Yesterday 11:37 PM
2 Replies, 2,657 Views
$115 Buttonwillow Raceway August 30-31st
Aug 21st, 2014 06:29 AM
by harvie
Last post by harvie
Yesterday 10:28 PM
1 Replies, 302 Views
Amp and Sub Woofer: Seeking Help & Advice
Aug 18th, 2014 05:17 AM
Last post by SteveM3
Yesterday 10:12 PM
1 Replies, 388 Views
Fan coming on when engine cold and staying on after engine turned off
Yesterday 10:08 PM
Last post by Eviek14g
Yesterday 10:08 PM
0 Replies, 298 Views
Semi-Integrated Sat Nav Question
Yesterday 12:43 PM
by dhosein
Yesterday 09:23 PM
1 Replies, 196 Views
Wheel & Tire Center
