Cooper Autobox problem - MINI Cooper Forum
post #1 of 1 (permalink) Old Feb 24th, 2014, 09:19 PM Thread Starter
Local Time: 12:14 PM
Hi
Got a bit of a strange one. I have a 2009 Auto Cooper Clubman. This morning the display in the tacho that shows P,D,N and R kept flashing between DS (manual mode) and D. It also wouldn't change gear, so I had to use the paddle shifters. Interestingly this evening it drove fine in normal Auto mode but when I move the gearshift to the left to engage DS(manual mode) nothing happens and the display still shows D instead of DS. Any ideas? Is it worth disconnecting the battery to perhaps reset the gearbox control module or will this set the alarm off and/or upset any settings? TIA
Reflexboy is offline
mini cooper s cold start problem njsupplies General Discussion 8 Nov 30th, 2015 01:44 PM
MINI COOPER S Convertable 53plate Exhaust problem archerluke Second Generation MINI Suspension 1 Mar 31st, 2013 06:54 PM
Cooper S starting problem Goffy Second Generation Faults & Fixes 5 Jan 24th, 2013 07:49 PM
cooper diesel problem s5sport General Discussion 2 Dec 9th, 2012 04:08 PM
2010 Mini Cooper S starting up problem Master_Yi Second Generation Faults & Fixes 2 Oct 19th, 2012 07:37 AM
