R56 Sunroof will Open.. But not close! - MINI Cooper Forum
post #1 of 4 (permalink) Old Feb 26th, 2014, 08:27 PM Thread Starter
Local Time: 01:20 PM
As stated in title.. sunroof opens perfectly via button.
However, if you push it to close it - the motor works for a sec to go forward and then stops. It sounds like it's clunking on something.. hence why stopping..
Any ideas??
maxruddock12 is offline
post #2 of 4 (permalink) Old Mar 5th, 2014, 05:24 AM
Quoted: 2 Post(s)
Cyprus Male
Does it open back by itself? In most of the cases, the ECU thinks that there is something trapped (high friction) so it will stop the motion and automatically reverse it.
Try to close the roof, by pushing and releasing the button in quick successions. This way you disable the anti-trap mechanism and you can see if the problem is that or not...
If it is, I recommend greasing your rails and then re-calibrating the sunroof's ECU. Since it measures voltage to determine friction, a not-so good battery can also be the cause.
alexcannas is offline
post #3 of 4 (permalink) Old Mar 10th, 2014, 08:26 PM
Guys,
Check out ALL the other threads on these issues. - Might help?
Earnest Lee is offline
post #4 of 4 (permalink) Old Jul 2nd, 2014, 06:35 PM
Copper s owner
Male
How do you find them on here as I need to shut my roof that's stuck
Grey Cooper is offline
Tags: , , , , , ,
Sunroof open only in raised position Madox First Generation Interior & Ice 1 Dec 22nd, 2013 02:04 PM
2007 MCS R56 boot open warning light/message on dash, squeal & rear wiper not working LadyUK Second Generation Faults & Fixes 3 Oct 31st, 2013 05:27 PM
R56 sunroof sticking issue (possible repair) alex21.2010 Second Generation Faults & Fixes 0 Feb 4th, 2013 08:53 PM
R56 Sticky sunroof when car is stationary. BMW says replace!? Aboutstu General Discussion 5 Jan 30th, 2013 07:50 PM
R56 Boot WONT open - advice/help/support required please? LadyUK Second Generation MINI Cooper S 6 Nov 26th, 2012 09:03 AM
