R56 Mini First (1.4) lumpy idle - MINI Cooper Forum
post #1 of 3 (permalink) Old Feb 27th, 2014, 10:31 PM Thread Starter
Local Time: 04:50 PM
My wife has a 59 plate Mini First which had elevated HC readings at the last MOT, but the re-test just scraped under 200 ppm.
Her Mini has started idling lumpily (~650 - 700 rpm) and sounding a little raspy at low revs (< 2500).
I stuck my OBD cable on this evening and the o2 sensor seemed to be reading < 1v which seems a little low to me, I was expecting >= 1.5v (see attached*)
After reading h t t p://w w w.mini2.com/forum/second-generation-faults-fixes/206833-mini-failed-emissions-test-second-time.html I'm tempted to get some cleaner for the cat, but are my o2 readings out of whack or am I miss-reading them?
(*columns are: PID, sensor, current reading, units, min, avg, max)
Name:	Screen Shot 2014-02-27 at 22.05.45.png
chrisgedrim is offline
post #2 of 3 (permalink) Old Mar 5th, 2014, 02:15 AM
United-Kingdom
Had a similar problem with our 2007 1.4 R56 70k miles which seems to be fixed now.
There were no OBD fault codes but we had a lumpy idle and slight hunting up and down with a flat spot at 2k-3k rpm and CO and HC emissions were both above MOT test limits.
It was time for a service so it had an oil change with new oil, air and fuel filters and a new set of plugs - which did not improve things.
We checked for an unmetered air intake leakage. Nothing found.
Next the throttle body was given a thorough internal clean. RESULT! - the CO reading reduced by 75% and HC's by 60%, well inside the MOT requirement.
It idles much better now and the flat spot disappeared.
I hope this helps with your problem.
Stephenda is offline
post #3 of 3 (permalink) Old Mar 16th, 2014, 05:42 PM Thread Starter
Update
Thanks for the advice
Finally got a good enough day with some spare time to have a spanner...
Replaced the air-filter and went for a run out; the car ran less lumpily, but ended up with a P1111A being thrown, so I think I need to clean the lambda sensor (and the throttle body while I'm doing it) and see if that makes things better
Tags: ,
R56 Mini Cooper Erratic surging at idle from cold start Norfolk-Mini Second Generation Faults & Fixes 7 Mar 23rd, 2016 02:42 AM
2006 1.4 Mini One D Idle Knocking Noise Just purchased. quemlar007 First Generation MINI One D 1 Sep 30th, 2014 02:46 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 06:36 AM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 07:11 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 06:29 AM
