Fluctuating Idle - MINI Cooper Forum
post #1 of 1 (permalink) Old Mar 7th, 2014, 12:01 PM Thread Starter
Local Time: 02:09 PM
England Fluctuating Idle
Hi all,
I have tried searching for this and i cannot seem to get a definitive answer.
I have a 08 R56 Cooper, when i started it after a short journey the idle was fluctuating from normal level ~800rpm down to close to maybe 200rpm (as if it was stalling) then back up and this carries on.
Drove off and it seemed to run fine no hesitation or lack of power and when i stopped it idled normally.
No error codes
I have not had it on cold start only once warm.
Any suggestions
borinous is offline
R56 Mini Cooper Erratic surging at idle from cold start Norfolk-Mini Second Generation Faults & Fixes 7 Mar 23rd, 2016 02:42 AM
My cvts idle changes with air con Josimo41 First Generation CVT & Automatic 2 Feb 20th, 2014 08:35 PM
Engine cutting out on idle Diedrik Second Generation Faults & Fixes 13 Feb 19th, 2014 03:32 PM
Mini Cooper High Pitched Squeaking Noise When Idle cp_22 Second Generation Faults & Fixes 9 Oct 19th, 2013 11:36 PM
Idle Speed problem ptbomini First Generation MINI Tuning 1 Aug 27th, 2012 11:38 AM
