Water pump/Tensioner/Idle wheel - MINI Cooper Forum
post #1 of 2 (permalink) Old Mar 17th, 2014, 11:22 PM Thread Starter
Local Time: 06:54 PM
Hi Ladies and Gents
Got a 1.4 First and just put a New engine in it - Bent Con Rod due to being Driven through a puddle/Lake
Swapped the water pump , "tensioner/Idler" over and the Alternator and Bottom Pulley from the Original Engine
Gone to put the Drive belt on for the Alternator and it Feels "tight"
Ran it up and it eaten the outer belt off the Water pump pulley - Any ideas why ?
Do these "contract" when removed ?
Thanks in Advance Stu
Stu172 is offline
post #2 of 2 (permalink) Old Mar 18th, 2014, 02:18 PM
Local Time: 07:54 PM
Quoted: 53 Post(s)
You need to check all the pulleys that are running on the same belt are all exactly in line, if they are misaligned at all this can lead to a noisy belt and excessive belt wear.
The Nun is offline
water in rear boot floor tool area jonjeffryes Second Generation Faults & Fixes 11 May 7th, 2015 04:17 PM
Water under the rear seats and in the boot Emily88 Maintenance & MINI Care 5 Mar 30th, 2014 04:32 PM
Space Saver Spare Wheel leethallee Wheels, Tyres & Brakes 7 Dec 17th, 2013 05:28 AM
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 03:06 PM
2 spoke steering wheel replacement. digitaluk Second Generation Interior & Ice 4 Mar 23rd, 2013 11:57 AM
