Windscreen Washer Indicator always on - MINI Cooper Forum
post #1 of 8 (permalink) Old Mar 30th, 2014, 08:28 PM Thread Starter
Local Time: 05:07 PM
Quoted: 3 Post(s)
Australia Male
Garage
New Zealand Windscreen Washer Indicator always on
My next problem on my 2010 R57 is the fluid level indicator for the windscreen washer is always on, I thought the reservoir was empty but when I went to top it up it was already full!
Any ideas on how to resolve this, is it just a matter of pulling the sensor from the reservoir and cleaning it? or is the sensor inside the pump somewhere?
burnstar is offline
post #2 of 8 (permalink) Old Mar 31st, 2014, 08:25 AM
Local Time: 07:07 AM
Quoted: 53 Post(s)
The sensor is in the bottom on the washer bottle, accessed behind the left front wheel arch liner.
You just pull the sensor straight out of the container, after disconnecting the wiring plug, obviously catch all the water in a container, and theres a sealing grommet which should be undamaged and coated with an anti seize compound before replacing and then the unit pushed back into place.
Looks like some sort of reed/float valve, could well be stuck and need a clean.
The Nun is offline
post #3 of 8 (permalink) Old Mar 31st, 2014, 08:40 AM Thread Starter
Quoted: 3 Post(s)
Australia Male
Garage
Thanks I'll give that a go in the morning. Hopefully its just blocked and not faulty!
burnstar is offline
post #4 of 8 (permalink) Old Apr 1st, 2014, 06:24 AM Thread Starter
Quoted: 3 Post(s)
Australia Male
Garage
New Zealand
Pulled out the float this afternoon and it looks like the floating part of the float is missing, pulled the reservoir out thinking it's in the bottom of the bottle but no sign of it.
Called BMW spares and one is on order for a mere $70
What it looks like
What it should look like
burnstar is offline
post #5 of 8 (permalink) Old May 31st, 2014, 02:06 AM
Not Normal.
Local Time: 03:07 AM
Uruguay Male
About replacing the sensor
Replacing the sensor for the new one worked for your warning issue?
miniuy is offline
post #6 of 8 (permalink) Old May 31st, 2014, 03:48 AM Thread Starter
Quoted: 3 Post(s)
Australia Male
Garage
Yep with the new one the problem has been fixed
burnstar is offline
post #7 of 8 (permalink) Old Jan 22nd, 2015, 02:08 PM
boatman2500's Avatar
Local Time: 06:07 AM
Quoted: 1 Post(s)
I'm having the same problem, how did you end up accessing the sensor? and where is it on the washer fluid reservoir?
boatman2500 is offline
post #8 of 8 (permalink) Old Jan 23rd, 2015, 12:20 AM Thread Starter
Quoted: 3 Post(s)
Australia Male
Garage
New Zealand
Removing the reservoir is a bit fiddly, you have to access it via the wheel arch, this involves removing the plastic cover in the wheel arch, there are a few screws that hold the reservoir to the car and then it's a puzzle game to twist the reservoir around to get it to come out.
Although I think you can just unscrew it and move it enough to get the sensor out. (I removed it from my car because at the time I didn't know how it was causing the warning light the problem)
burnstar is offline
Rear windscreen washer not working Gilli Welcome New Members 3 Apr 6th, 2013 10:47 AM
Windscreen washers both not working ;/ Blueprint First Generation Faults & Fixes 4 Feb 15th, 2013 06:03 PM
Mini windscreen ident88 General Discussion 1 Jan 29th, 2013 12:05 PM
Windscreen Wipers are driving me INSANE!!!! bax2079 First Generation Faults & Fixes 5 Nov 5th, 2012 04:44 PM
