R56 cooper S wheel speed sensor fault - need genuine mini part? - MINI Cooper Forum
post #1 of 1 (permalink) Old Apr 23rd, 2014, 06:19 PM Thread Starter
Local Time: 09:26 PM
Northern Ireland
Question R56 cooper S wheel speed sensor fault - need genuine mini part?
Hi all,
Have a fault showing front driver side wheel speed sensor
After fitting a new 28 part the problem still existed which was to no surprise as the part fitted was a slight different shape to one I removed from the car
The part which came out of the car, the end which goes into the back of the hub had a slanted end on it whereas the new one I bought the end was straight. This part was showing up as the correct one for the car though so has anyone else experienced this?
I have a part ordered from mini at a cost of 83.80 which I hope sorts the problem.
Anyone here know if the genuine part is needed and that the cheaper copies do not sort this problem?
DanN92 is offline
R56 Mini Cooper Erratic surging at idle from cold start Norfolk-Mini Second Generation Faults & Fixes 7 Mar 23rd, 2016 02:42 AM
Mini Cooper S R56 Timing Chain Tensioner Mini Cooper S BUSTED Second Generation Faults & Fixes 23 Sep 4th, 2015 05:24 PM
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
Mini R56 Slow Speed Clunk From Rear When Cold gaznav Second Generation Faults & Fixes 1 Nov 20th, 2014 06:38 PM
Advice/help needed. Mini cooper - Chrome filler cap. Poor Service. What would you do? digitaluk Second Generation MINI Exterior 5 Mar 22nd, 2013 01:28 PM
