Upgrade from base to S clutch - MINI Cooper Forum
post #1 of 9 (permalink) Old May 8th, 2014, 09:39 PM Thread Starter
Local Time: 10:45 AM
My daughter just burned up her clutch on an 08 base Cooper. I want to upgrade to the larger clutch that is used on the S for two reasons: First I can't find a reasonably priced flywheel for the base model. There are plenty of single mass flywheels for the 228mm clutches but none for the 200mm. 2nd, I hoping the larger clutch will last longer.
Can any one tell me if the 228mm clutch and flywheel kit will fit the base cooper? Is there anything else I need to change out? Looks like the release fork is a different part number so I'm assuming I need to replace that also.
mark13152 is offline
post #2 of 9 (permalink) Old May 9th, 2014, 02:55 AM
Local Time: 05:45 PM
United States Male
It really depends on the driving style of your daughter. I have a lead foot and like to drive in reverse really fast. I moved from the dual mass oem over to solid mass. You should be able to use a valeo solid flywheel conversion kit. Exeddy and Clutchmaster kits are a little pricey but hold up well during street and race conditions.
TheGypseDanger is offline
post #3 of 9 (permalink) Old May 9th, 2014, 04:43 AM Thread Starter
Thanks for the info... the single mass should fit her driving style better. We don't by the Mini to baby it, right!
I still need to know if I can replace the 200mm clutch with the 228mm clutch and what parts have to change besides the flywheel.
post #4 of 9 (permalink) Old May 12th, 2014, 04:00 PM
United States Male
So this is a qoute from Ollypop0
Ok so up date on the gearbox conversion. After much research online and getting the old man on the case too, we contacted John Tee at Minigearboxes.co.uk who although being on spring break kindly gave us a parts list for the conversion. It turns out it is not a straight one in one out swap (no such luck) but it's not as complicated as the Midland to Getrag switch. The parts you need, for anyone that's interested are as follows.
2X Drive shafts
Transmission mounting
Flywheel & Clutch
Control cables & Selector box
KN air filter
So next step sourcing parts.
Keep you posted
post #5 of 9 (permalink) Old May 13th, 2014, 01:51 PM Thread Starter
I appreciate all the research. Turns out to be much more complicated than I expected. I think I'm going to have to stick with the original 200mm clutch.
post #6 of 9 (permalink) Old May 19th, 2014, 10:25 AM
Banned
Yeah i also appreciate you all to bring this information to me also.I am glad to know about it because i have a little knowledge about it but i can full handled it.I also watched some documentaries about this upgrade on you tube.So now i hopefully upgrade it in my garage.
habi222 is offline
post #7 of 9 (permalink) Old May 19th, 2014, 06:36 PM
United States Male
No problem =)
post #8 of 9 (permalink) Old May 20th, 2014, 03:30 PM Thread Starter
I wimped out and went with the standard clutch. Let us know how the upgrade goes. Take lots of pictures.
post #9 of 9 (permalink) Old Aug 11th, 2014, 09:29 PM
Local Time: 09:45 AM
Clutch for Base model - OEM vs S vs Aftermarket?
2X Drive shafts
Flywheel & Clutch
KN air filter
Keep you posted
Hi I'm new to the group and I'm curious abut the update on your upgrade from Base model clutch to an S clutch and how it went and if you finished?
I'm asking because I just bought a 2007 Mini convertible base model with 116K miles on the odometer and a month and about 450 miles of driving after buying it the clutch broke (very bad burning smell and car won't go forward or reverse.)
So, it's in my local BMW independent mechanics shop and I'm wondering if he should replace with stock OEM clutch and flywheel or convert to S setup or are there other aftermarket brands that last better than OEM? From what I've read on the net the stock OEM parts have a bit of overheating issues due to using some lower quality parts such as throw out bearings and such?
My wife drives this car as her daily run around town car so I don't want to go to a race clutch but something more durable and longer lasting than OEM would be good?
Thanks in advance for any advice!
bmoody33 is offline
Looking for feedback on clutch issues ('08 Clubman S) Blue08ClubmanS MINI Clubman 8 Jan 25th, 2014 08:39 AM
Clutch bleed Clarification MiniDeLux Second Generation Faults & Fixes 0 Nov 21st, 2013 02:37 PM
Stubborn Dealership over Clutch Bleed MiniDeLux Second Generation Faults & Fixes 0 Mar 18th, 2013 10:45 AM
2012 Cooper S clutch ellabean69 General Discussion 6 Nov 24th, 2012 01:46 PM
What RPM do you start 1st with? thewhitenight000 First Generation MINI Cooper 2 Aug 8th, 2012 06:19 AM
