water problem - MINI Cooper Forum
post #1 of 3 (permalink) Old May 9th, 2014, 01:56 PM Thread Starter
blitzpower's Avatar
Local Time: 11:11 AM
England water problem
can anyone tell me why my water keeps dropping in the expansion bottle i have a mini cooper s 2003 i have had a sniff test done and everything is fine with head gasket temperature runs dead centre and no water drops on the floor really confused. Helllpppp p.s the car has only done 46000 mls
blitzpower is offline
post #2 of 3 (permalink) Old May 9th, 2014, 02:25 PM
Scotland
You could try bleeding the system first.
Check out tech info at pelicanparts.com
I had a similar problem. Combination of things. Firstly there was a small leak in the radiator. Practically invisible to the human eye! No visible evidence of leaks on the floor. Only got picked up when system was pressure tested. Also thermostat was on the bung which didn't help!
As I was replacing the thermostat I drained the system and flushed it out. Before installing the new stat, I got some RadWeld and put that in the system and ran it per instructions. I then drained the system again, replaced the stat and filled with coolant. Ran it now for a couple of hundred miles and water level steady.
Funsize Min is offline
post #3 of 3 (permalink) Old May 9th, 2014, 03:11 PM Thread Starter
blitzpower's Avatar
thanks for the info funsize min will give it a go once again thanks..
Water under the rear seats and in the boot Emily88 Maintenance & MINI Care 5 Mar 30th, 2014 05:32 PM
Intermittent sound problem with IPOD and AUX inputs dsmith Second Generation Interior & Ice 3 Jan 22nd, 2014 09:30 AM
R56 Overload indicator light, no water in engine issues LadyUK Second Generation Faults & Fixes 1 Nov 13th, 2013 06:26 PM
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 04:06 PM
Mini problem - please help!! HelpMe General Discussion 13 Jan 18th, 2013 10:00 PM
