Serious Issues - DIY Addtional JCW Gauge Install - MINI Cooper Forum
post #1 of 3 (permalink) Old May 17th, 2014, 06:27 PM Thread Starter
Local Time: 12:01 PM
Scotland
Hey,
So, trying to be a smart Ar... I decided to myself to install the JCW Addtional gauges / instruments myself rather than pay a dealer 150 to install.
Seemed simple enough, couple of wires to throw about, nothing to major, but by god it had turned into a living nightmare.
I need any help at all, i think the fault lies with the footwell control module, but any advice you can give will be really appreciated.
So, battery disconnected installed kit, Rewired plug behind steering wheel and wired the two cables to the correct pins on the footwell control module.
Put the Key in ignition. and wipers came on and wouldn't switch off, no power to gauges at all. Started car, and warning light up for DSC. Windows responding to switch, and on door opening, they go down, close door, they do not go back up!
Checked, checked and rechecked, all all functions working, lights etc, but same faults no matter what i do. All is in order, i decided to remove and go back to stock to see if it was the install causing the issues, but low and behold even with stock wiring, same issues - I have read a couple of other threads on NAM, and problems all point to FCM, but i have checked and checked again can find nothing wrong, and to top it all off i've snapped one of the crimps within the X1880 plug behind the steering wheel, it has not been a good day.
Any ideas?
It's not mission difficult Mr Hunt, It's Mission Impossible
Mission difficult should be a walk in the park for you....
Mission Impossible is trying to get your wife to understand that we really do need a Cooper S
G17RDY is offline
post #2 of 3 (permalink) Old May 17th, 2014, 07:36 PM
Quoted: 53 Post(s)
I wouldnt be at all surprised if you dont have to reprogram the computer to tell it youve fitted the gauges, its suddenly seeing something it doesnt recognise and it thinks theres an electrical fault?
It might have to go to the dealers after all?
The Nun is offline
post #3 of 3 (permalink) Old May 18th, 2014, 04:43 PM Thread Starter
Scotland
According to the documentation, it doesn't need coding.
I'll call dealers tommorow and see when i can get it fixed!
G17RDY is offline
