Bad brake calliper piston - MINI Cooper Forum
post #1 of 3 (permalink) Old May 26th, 2014, 09:56 PM Thread Starter
Local Time: 05:02 PM
Quoted: 1 Post(s)
Luxembourg Male
Just a little info in case anyone else is having the same issue. Have a 2009 Mini Cooper Clubman (diesel engine) with 130,000km (80,000miles). For the last two weeks, pushing and holding the brake pedal results in what I can only describe as a clunking noise. Sounds a little like hot water pipes expanding. The longer/harder you push the brake, the more the clunking.
Turns out the driver's side (left hand drive) brake calliper piston is going bad. Repair will cost me €350 including changing the piston and flushing the brake fluid. Dealership says the calliper is more expensive for the diesel engine as the heavier engine up front requires a bigger calliper piston. For the Cooper S model, the price would have been about €250.
Not changing it means at some point the brake is likely to bind.
Hope that might help someone.
MiniDeLux is offline
post #2 of 3 (permalink) Old Jun 13th, 2014, 10:38 PM
Local Time: 04:02 PM
Have you thought about buying a calliper rebuild kit, they are pretty cheap and it is not a difficult job to do. Might save you some pennies and yeah, you don't want to let the brakes bind, the heat will might warp the disc.
Pomsteroonie is offline
post #3 of 3 (permalink) Old Jun 18th, 2014, 11:21 AM Thread Starter
Quoted: 1 Post(s)
Luxembourg Male
Don't have much time to fiddle with the car on my own. Also, I live in the countryside and it's my only car. Can't afford to mess anything up.
Your point is well taken, though.
rear brake caliper piston dustcover replacement mini_scotsguy Wheels, Tyres & Brakes 0 Aug 15th, 2012 10:25 PM
