R56 Cooper compression test help - MINI Cooper Forum
post #1 of 2 (permalink) Old Jun 18th, 2014, 10:59 PM Thread Starter
Local Time: 01:02 PM
Hi guys still having the idle/misfire problem on the cooper tried everything,Still thinking a block / cylinder head problem or head gasket i tested the compression again today plugs removed and dry and got totally different readings from the last test..... possible as my mates guage is old i used a newish one this time around.......looks very odd....seems way too high and a differential between 2+4 any ideas anyone
CYL 1-205
CYL 2-218
CYL 3-205
CYL 4-225
CYL 1
CYL 2
CYL 3
CYL 4
pawea is offline
post #2 of 2 (permalink) Old Jun 19th, 2014, 09:42 AM
England
There's normally a 10% difference which is acceptable.
Did you use a screw-in type of tester? From the picture it looks like a push-fit type which isn't so effective. I used to warm up the engine before taking readings and keep the throttle open.
If there's a wide discrepancy in readings,then squirt some light oil into the plug hole. If compression improves,then it indicates a piston problem. If no difference,then it could be a valve problem. The Haynes manual quotes 8-12 bar with 3 bar maximum difference between cylinders.
David T-H is offline
Which diagnostic tool for R56 cooper? LizzyG Second Generation Faults & Fixes 10 Aug 10th, 2015 02:47 PM
Difference in chassis and body R50/53 → R56, Cooper → Cooper S d-b First Generation MINI Cooper 0 Apr 12th, 2014 07:44 PM
True running costs of R56 Cooper S? cupofjavaa General Discussion 8 Nov 23rd, 2013 07:25 AM
Does r56 cooper S front bumper fit r56 cooper? irfan.s Second Generation MINI Cooper 0 Feb 14th, 2013 10:22 AM
