Mini Cooper inlet camshaft corrosion. - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 24th, 2014, 11:29 PM Thread Starter
Local Time: 10:06 PM
United-Kingdom Mini Cooper inlet camshaft corrosion.
My wife bought her 59 plate petrol Mini Cooper from Rybrook Mini in Worcester in November 2012.
In July 2013 the orange engine fault light came on.
Rybrook had the car in and diagnosed a problem with a corroded inlet camshaft and fixed it under Mini's original 3 year warranty.
Recently, in June 2014, the engine fault light came on again. Rybrook had the car back in and diagnosed the exact same problem again.
I thought that as it was less than twelve months since this problem had supposed to have been fixed the first time it would be rectified for no further charge. But I was told by Rybrook that this was not the case and the cost of the repair would be £1400.
Oh well we though, good job we took out Mini's extended warranty in November 2013, when the original 3 year Mini guarantee expired, (at a cost of £36 per month). But we were dismayed to be told by Mini that the fault would not be covered under the warranty and we would have to pay.
Rybrook did say that for goodwill reasons they would reduce the bill to £1000.
When queried, Rybrook/Mini say the fault is due to driving style and the corrosion is due to a build up of mositure because of too many short journeys.
My wife drives the mini to work daily, a trip of about 5 miles each way and at week-ends goes shopping, a run of around 25 miles.
I find this cause hard to believe as this type of use can not be unusual for a Mini and when asked if they see a lot of Minis with this problem, Rybrook replied that they did not.
As I see it, Mini are effectively saying that even a petrol Mini is not a suitable car as a run-about or a short commute and unless you are doing reasonably long trips you are going to encounter the above problem for which you will be responsible.
Am I right to feel aggrieved?
MiniDiddy is offline
post #2 of 3 (permalink) Old Jun 24th, 2014, 11:42 PM
Hi ya
As I understand the spares if you buy a bit from mini you have a two year warrantee. For instance I fitted a cam chain tensioner that fail just after a year I took it in to mini and they changed it free of charge.
I was told all work and parts are covered for two years parts and labour so I would query that. a camshaft should not corrode it's in always covered in oil I think some one is telling porkies, something does not sound right.
I think also you can clam it's not fit for purpose if it's failing that often I think that's covered for three years as a consumer right, you would have to check that though
I would ask for pictures and say your going to call mini head office and speak to them
do you have the receipt from the original replacement even if it warrantee I always get a receipt
Feel you pain
marque is offline
post #3 of 3 (permalink) Old Jun 25th, 2014, 08:49 AM
Local Time: 11:06 PM
Quoted: 53 Post(s)
Makes you wonder if the fault was a rusting camshaft doesnt it, did you ever ask to see the one removed? I doubt you thought about it?
It must be a very clever diagnostic system to tell if the camshaft has gone rusty, and if its that bad in such short a time it cant be hardly getting any oil at all?
To me, I think theres something they arent really telling you here, if you have it done again tell them you want to see the parts replaced before they bin them, and see if they cough.
Bit like a post here a while back where the garage told the owner they had adjusted the tappets because it wasnt running right, and they dont need it as they self adjust.
The Nun is offline
Tags: ,
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 01:33 PM
2014 MINI Cooper S Revealed in Spy Photos AutoGuide.com MINI News 14 Jan 13th, 2015 08:58 PM
Mini Cooper S Seat Heater Fire Paul.Armstrong First Generation Faults & Fixes 0 Apr 29th, 2014 03:08 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 07:11 PM
