Engine idle , cuts out , no acceleration - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 7th, 2014, 11:47 PM Thread Starter
Local Time: 09:41 AM
Hi everyone , i need a little advice am new to the mini forum .
I just purchased a new mini cooper s 57 plate 23k , its hardly been driven and has had a new engine put in around three years ago .Its done around 1000 miles since engine change .
Every morning and any other time where the car has been sitting for a while it has difficulty starting it needs approx 3-6 starts and during those starts the engine judders and eventually stalls also if you press the throttle there will be no response.,then after a few failed starts it will fire up as if there is nothing wrong and the car will function well for the rest of the day.
Initially when it first happened i called the AA and it came up with a a coil failure .
I am quite stumped and would really like some good advice on this matter .
thanks
shane321123 is offline
post #2 of 2 (permalink) Old Jul 8th, 2014, 02:05 PM
Hi ya
I would get a good fuel system/injector cleaner though it first use something like bg44k and use some v plus in it. Do you here the fuel pump priming ?
Then I would be looking at your normal service parts filters, plugs etc for condition when was it last serviced ?
Then running a full diag on it with bmw dis looking at sensors, fuel pressures etc
It could be anything from a bad high pressure fuel pump or bad water temp sensor, but with out running a proper diag on it you could be chasing your self.
marque is offline
Tags: ,
Engine cutting out on idle Diedrik Second Generation Faults & Fixes 13 Feb 19th, 2014 02:32 PM
Dying engine at idle sunandsea Welcome New Members 0 Jan 2nd, 2014 03:36 AM
engine surge at idle rhymesayers90 First Generation Faults & Fixes 2 May 25th, 2013 11:20 PM
engine surge at idle rhymesayers90 First Generation Faults & Fixes 2 Apr 16th, 2013 07:57 PM
Engine revs up then down during constant acceleration JmichaelN88 Maintenance & MINI Care 2 Jan 24th, 2013 10:17 PM
