Water Pump & Air Conditioning Problems - MINI Cooper Forum
post #1 of 5 (permalink) Old Jul 9th, 2014, 02:31 PM Thread Starter
Local Time: 02:12 PM
Quoted: 1 Post(s)
Got a couple of problems with my standard R56 Cooper and was wondering if anyone knows if they are linked or what might be causing this.
Driving about in the city a couple of weeks ago and the engine warning light came on (yellow) to warn about engine temp. Checked the coolant and it was low. Topped it up. A few days later it was slightly lower again.
Got a local mechanic to have a quick look. He reckons the water pump isn't turning consistently, possibly due to the tension of the belt. He said there is a tensioner for this that may be broken. Does this make sense? Either that or the water pump is just knackered. There are no visible leaks though coming from the car.
I am now also noticing that the Air Conditioning isn't working properly. The light comes on okay and it blows out air but this air doesn't seem to be cooled enough.
If i turn off the Air Condtioning and turn the heat up, the normal fan blows out warm air. (If that's any help in diagnosing things).
Any ideas? Are these likely linked or just bad luck together?
Atomic8001 is offline
post #2 of 5 (permalink) Old Jul 9th, 2014, 04:54 PM
heathwebbo's Avatar
Local Time: 01:12 PM
The belt that turns the waterpump also turns the aircon compressor so it could be related
heathwebbo is offline
post #3 of 5 (permalink) Old Jul 10th, 2014, 09:51 AM Thread Starter
Quoted: 1 Post(s)
Okay, thanks.
So if the belt is possibly loose like the mechanic said, this makes sense that the air con and water pump aren't working properly.
Anyone know how many hours labour it would take to get access to and tighten this belt?
post #4 of 5 (permalink) Old Jul 11th, 2014, 06:44 AM
heathwebbo's Avatar
The tensioners adjust themselves so if the belt is loose it may just need a new belt which should be a 10 minute job to change but if it needs a new tensioner I am not sure how long to change one as I have only worked on R50s & R53s but I would have guessed at around 30 mins
post #5 of 5 (permalink) Old Oct 1st, 2015, 12:26 AM
Local Time: 12:12 AM
Australia
If i turn off the Air Conditioning and turn the heat up, the normal fan blows out warm air. (If that's any help in diagnosing things).
Hi mate,
I have got the same problems on my R56 just the sequence was the other way around, noticed the air con not blowing cool air first and the temp warning light started coming on the next day.
Have got a new belt fitted recently when i got a valve job done abt 2 months ago (pictures of the burnt valve if this interests anyone). The mechanic says its the friction/tension assembly.
Wondering what turned out to be the problem on your MINI and what was the fix? Thanks
ID:	192306   Click image for larger version
ID:	192314   Click image for larger version
ID:	192322   Click image for larger version
MINIProDG is offline
Water in footwell- air conditioning ?? PhilT Second Generation Faults & Fixes 3 Aug 2nd, 2015 03:54 AM
Auxiliary water pump noise palodelincak Second Generation Faults & Fixes 0 Feb 27th, 2014 12:17 PM
Water pump leaking coolant ozmusafir Second Generation Faults & Fixes 3 Jul 29th, 2013 01:24 PM
Timing belt misalignment due to water pump replacement sghani Second Generation Faults & Fixes 2 Sep 15th, 2012 04:17 PM
Timing belt issues due to water pump replace sghani Second Generation MINI Cooper S 3 Aug 9th, 2012 12:15 PM
