2010 air con fault - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 13th, 2014, 08:42 PM Thread Starter
Local Time: 05:01 AM
England 2010 air con fault
This might be simple fault but here goes
2010 mini one heater works ok
Put the air con switch on a cluck is heard and engine noise changes, I presume the condenser is doing something
No fan comes on therefore it doesn't go cold
I have had the gas checked all ok
I have read about fuses and relays
Anyone know where to start without going into main dealers ?
Thanks anyone
Beanzboy is offline
post #2 of 2 (permalink) Old Jul 14th, 2014, 08:27 PM
Quoted: 1 Post(s)
Scotland
Hi beanz I am a mini tech, that clunk u are feeling is ur a/c pump which is ran but your pollu v belt. If your not getting cold air the most common failure on r56 models is the condensor which is like a rad info of the coolant rad. Check for it being wet even though the rest of the car is dry.
Also how did u confirm you had enough air con gas?
Minitech93 is offline
Mini Cooper 2007 1.6 AIR Con - Am I stupid ? marksinnott General Discussion 3 May 9th, 2014 12:00 AM
Fitting air con into r50 Freelanderblue First Generation MINI Cooper 1 Jan 19th, 2014 11:49 PM
2010 Mini Cooper - Power Steering fault? stevieboy2k Second Generation Faults & Fixes 0 Nov 22nd, 2013 03:03 PM
air con noise Swardy First Generation Faults & Fixes 8 May 7th, 2013 08:22 PM
Air con issues HHMCS First Generation Interior & Ice 5 Sep 5th, 2012 11:28 PM
