Oil leak underneath car - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 20th, 2014, 05:34 AM Thread Starter
Local Time: 04:12 AM
Hi,
I noticed an oil leak underneath the car. Refer photos. It appears to be from a hex nut on the undercarriage as well as the oil filter drain plug.
I'm not sure if the oil is actually also leaking from the underbody cracks in the metal.
Greatly appreciate some advice.
Please refer attached pictures.
ID:	176801   Click image for larger version
ID:	176809   Click image for larger version
bbyc is offline
post #2 of 2 (permalink) Old Aug 15th, 2014, 03:21 PM
Local Time: 03:12 PM
Australia
Hello bbyc,
I have a 2010 clubman S chilli, and I have had so many problems with this car, even now it sits with another problem and cant drive it again this weekend - fed up with it actually.
A few problems ago - probably the start of all problems, was a major oil leak, where it had heavily leaked all over the driveway, and then all down through the diff etc. I am sure that this was the beginning of the so called Sludge in the engine and then the Super Knock problem.
I would get your mini to the dealer and have it checked before it leads to more sinister internal unseen engine problems - actually I now take my mini to a local motor repairer, who are very helpful, but dont have the equipment to do major repairs. They check the error codes first, then I go back to the BMW dealer, cause I dont trust the BMW service anymore, at least now I go with a list of the error codes. Hope your mini is sorted for you. cheers Tracy
TracyOZ is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 09:09 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 12:33 PM
2005 Cooper S Oil Leak - Travels the length of the car? Apprentice First Generation Faults & Fixes 1 Jun 2nd, 2014 06:58 AM
Oil leak need your help..., nickw First Generation Faults & Fixes 8 Sep 24th, 2013 03:38 PM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
