problem starting - MINI Cooper Forum
post #1 of 1 (permalink) Old Aug 5th, 2014, 04:05 PM Thread Starter
Local Time: 08:19 AM
problem starting
Hi, i drive a 2010 MCS with N18 engine, recently i have problem starting the car, when i depressed the start button the engine do not crank and sometime if takes a few time before the engine starts to crank and start up. But at time it starts on first press. Both car battery and key fob battery are in good condition. It is not the cold start issue as temperature here is not cold.
Does anyone here experience the same issue? Can share where is the fault.
I
Genesis12 is offline
Weird starting problem / FUEL PUMP, FILTER ? Schakal General Discussion 0 Oct 31st, 2013 11:55 AM
Cooper S starting problem Goffy Second Generation Faults & Fixes 5 Jan 24th, 2013 07:49 PM
Central locking/ car starting problem in cold/ wet weather C & C mini First Generation Faults & Fixes 3 Nov 4th, 2012 05:11 PM
2010 Mini Cooper S starting up problem Master_Yi Second Generation Faults & Fixes 2 Oct 19th, 2012 07:37 AM
Weird Starting Problem - Electrical, Lock or Computer Maybe? Mrelia First Generation Faults & Fixes 4 Aug 18th, 2012 03:46 PM
