Boot opening problem - MINI Cooper Forum
post #1 of 5 (permalink) Old Aug 7th, 2014, 04:17 PM Thread Starter
Local Time: 02:07 PM
England Boot opening problem
Hello all
I have an odd fault with my 2010 mini one
When I press the central locking the car locks the doors and boot, I unlock doors are open but the boot wont?
There is no pressure on the boot opener (above the number plate) whether it is locked or not
The only way to open it is by pressing the boot open button on the key fob, I've never used this button in 4 years
I am presuming that the locking is working and that the switch is at fault?
Is there a solenoid in there?
Anyone any ideas?
How do I get at the switch?
Thanks anyone for there help
Beanzboy is offline
post #2 of 5 (permalink) Old Aug 7th, 2014, 06:12 PM
Local Time: 01:07 PM
Quoted: 40 Post(s)
In the settings menu, you can set the fob unlock button to unlock just the driver's door or all the doors/boot. It would be worth checking that that is set as you want it. And I think the setting is unique to each key fob, so you may want to do it with both.
"But I've never changed it" doesn't count as there are criminals who break into you car, leaving no trace, just to alter menu settings. They are the same people who used to break into houses to cancel VCR record settings.....
Angib is offline
post #3 of 5 (permalink) Old Aug 8th, 2014, 07:31 AM
Quoted: 53 Post(s)
Pity we cant find a few who break in to do the cleaning and leave with no trace.
The Nun is offline
post #4 of 5 (permalink) Old Aug 15th, 2014, 07:03 AM
Quoted: 1 Post(s)
United Kingdom View den123's Classified Ads
its the boot handle there is a chip inside that after time rain and with washing down knackers it the easy way is to replace the complete handle look on ebay mine went few weeks ago same problem
den123 is offline
post #5 of 5 (permalink) Old Aug 15th, 2014, 10:30 PM
There is a motor with gears that operate the latch...no solenoid. Mine froze up recently and I had to access bottom panel inside car to un screw lock. A piece of plastic off the "U"
hook on the hatchback came loose and lodged permanently in the lock. Had to cut off with sawsall.
ldaugherty is offline
Tags: , , ,
opening the boot - am i being special?? tracemul7 Second Generation MINI Cooper S 16 Oct 7th, 2014 05:06 AM
Intermittent sound problem with IPOD and AUX inputs dsmith Second Generation Interior & Ice 3 Jan 22nd, 2014 08:30 AM
R57 Boot issues villiham General Discussion 2 Mar 28th, 2013 01:44 PM
09 cooper convertible boot lid problems Aysh Second Generation MINI Convertible 4 Dec 3rd, 2012 07:59 PM
mini convertible boot opening problems mase84 First Generation Faults & Fixes 0 Dec 3rd, 2012 06:20 PM
