R56 N12 on her last leg...HELP! - MINI Cooper Forum
post #1 of 3 (permalink) Old Aug 9th, 2014, 03:00 AM Thread Starter
Local Time: 02:27 AM
Canada Female
Base model R56 non s , After 2 weeks of being painted MINI has has considerable loss of power. Brought to local mechanic. Top guide rail broke. Whole Timing chain assembly replaced. Serpentine belt replaced and camshaft seal replaced. Solenoids cleaned and switched. Codes now being thrown are 2845 VANOS Exhaust Activation Movement. 2781 Combustion Misfire Several Cylinders. 2771 Combustion Misfire Cylinder1. 2779 Combustion Misfire Cylinder 4. 283D VANOS Exhaust Adaption Stop. Has anyone experienced an excessive Blowby? (NO JOKES PLEASE!!) My Cooper has registered 240psi on #3 piston. And 60 psi on # 1,2 and 4. My local mechanic is taking her appart one last time to pull a piston to check the rings. After this I may be forking out for a new motor. It's been 47 days and counting since I drove my MINI. I need her back..I've read and asked if it was carbon on the back of the intake, coils, the Ac being on, soft hoses, Exhaust leak all were checked and are fine. Is there something we can do to save her? She has a bad idol, shakes whole car, stalls under 1000k but runs smooth over 1000k.
enzie is offline
post #2 of 3 (permalink) Old Aug 11th, 2014, 10:30 AM
Local Time: 06:27 AM
Quoted: 1 Post(s)
Luxembourg Male
Compression values on 1,2 and 4 don't seem good at all. Suggestive of badly worn rings or other damage. Wonder if it could be related to valve damage as a result of timing chain issue? Think you have to get in there and look at the condition of the cylinders/pistons. Can the mechanic not use a flexible camera rather than breaking the engine down?
How many km's on this car? Were there problems before it was taken in to be painted? Did you bring this to the attention of the paint shop before driving off the lot?
MiniDeLux is offline
post #3 of 3 (permalink) Old Jan 12th, 2015, 01:09 AM Thread Starter
Canada Female
Sorry I asked a few forums about my plee this past summer I forgot to give an update here. I totally rebuilt my R56 n12 Cooper (non s). She is running like a charm now. Two of my pistons were cracked on the sides inbetween the rings causing excessive blowby. We replaced many different parts. Some in dire need like the serpintine belt and plugs. Now that I know about the timing chain rattle, we'll replace it before it ever gets that bad again. I since had my bumper repaired due to a minor bump this winter and never broght it to the same repair shop. (Never again). Total cost for the rebuild was around 6K. I plan on keeping her for a long while. At least I know what's under the hood. Thanks for your input and Motor on.
enzie is offline
Which diagnostic tool for R56 cooper? LizzyG Second Generation Faults & Fixes 10 Aug 10th, 2015 02:47 PM
January 2007 Registered, Is It An R56 ? tom64 General Discussion 6 Aug 7th, 2014 07:29 PM
Fire damage R56 MCS, need help from you guys! gtr_gtti Second Generation Faults & Fixes 6 May 24th, 2014 11:46 AM
R56 N12 2845 DME Vanos Exhaust Actuator Movement kentuckynet Second Generation MINI Cooper 5 May 20th, 2014 10:22 PM
Bye r53 hello r56 James burbidge General Discussion 12 Aug 29th, 2012 10:17 PM
