P2177/P2188 codes - MINI Cooper Forum
 2Likes
  • 1 Post By SeanC
  • 1 Post By Milpol
post #1 of 5 (permalink) Old Jan 10th, 2017, 09:17 PM Thread Starter
Local Time: 08:50 AM
Quoted: 1 Post(s)
P2177/P2188 codes
Hi, previously had P2188 (too rich at idle bank 1) which disappeared for a month after clearing. Today, EML came on again with P2188 and P2177 (too lean at idle after bank 1).
Any ideas what the actual problem is/might be.....seems a bit contradictory having too rich and too lean simultaneously
Dickiem is offline
post #2 of 5 (permalink) Old Jan 11th, 2017, 12:51 AM
Local Time: 09:50 AM
Quoted: 858 Post(s)
Bank 1 pre cat, bank 2 post cat. There are 2 Lambda sensors on the car. Now just because these codes have been triggered it doesn't automatically mean that the lambda's are at fault, it just means that this is the last line in the cars's sensors thats picked up a reading that its not happy with which may be caused by a component further upstream so I'd be checking any vacuum hoses, the coil pack or it could even be the high pressure fuel pump.
Milpol likes this.
SeanC is offline
post #3 of 5 (permalink) Old Jan 11th, 2017, 06:38 AM Thread Starter
Quoted: 1 Post(s)
Thanks Sean, I'll check the hoses first. How do u check a coil pack (no signs of rough running so nothing jumping out there).
Dickiem is offline
post #4 of 5 (permalink) Old Jan 11th, 2017, 08:11 AM
Local Time: 06:50 PM
Quoted: 179 Post(s)
Australia Male
Garage
Have a look at the coilpack, pull the HT leads off and check inside the sockets for corrosion. If corroded, clean them up with some fine wet and dry and the same to the ends of the HT leads.
SeanC likes this.
Milpol is online now
post #5 of 5 (permalink) Old Jan 11th, 2017, 11:12 AM
Quoted: 858 Post(s)
Socket 3 usually furrs up
SeanC is offline
P2127 and P2138 Check Engine Light codes Derek Ottman First Generation MINI Cooper 1 Mar 1st, 2017 12:50 PM
08 Mini copper S R56 misfire codes RunL0st Maintenance & MINI Care 5 Feb 16th, 2016 05:12 PM
Enhanced Fault Codes help nelsonian62 Third Generation Faults & Fixes 1 Feb 7th, 2016 09:38 PM
Help!! 7 fault codes!!! Shorjoa Second Generation Faults & Fixes 3 Apr 18th, 2015 03:04 PM
