Turbo Head shield removal - MINI Cooper Forum
post #1 of 6 (permalink) Old Apr 18th, 2017, 08:44 PM Thread Starter
Local Time: 12:31 AM
Quoted: 9 Post(s)
Hi All,
I need some help and advice on how to take off the heat shield around the turbo unit on a mini cooper clubman 2008, without taking the hall front off? IE grill, bumper, radiator etc....?
I am trying to replace the turbo oil feed pipe and its hallow bolt which has a mesh filter built in, as well as tightening the claim that fits the turbo on the the Cat, got some soot around it which I'm guessing is due to a loose clamp that joins the turbo to cat conveter.
Thank you in advance
Mini Trip is offline
post #2 of 6 (permalink) Old Apr 19th, 2017, 06:21 PM
Quoted: 12 Post(s)
Originally Posted by Mini Trip View Post
Hi All,
one thing you must do disconnect the battery first, as when you try and remove dpf filter it will hit alternator and spark or do damage,, and the answer to you question no you really do need to loosen the front.. you can undo it all and disconnect the turbo inter cooler pipe on drivers side get someone to hold the front away from car while you lifter filter out,, this is same if car is petrol or diesel,, stupid pain in arse job the first time.. also when you remove filter fit a new pipe at same time, i have had a number of them leak after being moved.. you can get away with leaning the filter forward with the front of car buts its just as easy to remove it,,
whoops thought was talking diesel sorry yes can get them off but tight on petrol, on diesels the dpf pipes dont like coming off and round off hence why i always would say to move the front out a tad
mike1967 is offline
post #3 of 6 (permalink) Old Apr 19th, 2017, 07:58 PM
Local Time: 01:31 AM
Quoted: 3 Post(s)
I just replaced my turbo oil feed hose on the clubman JCW.
I used my ratchet spanners and did not remove the front end. ��
WOE2 is offline
post #4 of 6 (permalink) Old Apr 19th, 2017, 10:12 PM
Quoted: 834 Post(s)
I've done it myself on a JCW without removing the front but as Mike says it's much easier to do with the front loosened up
Sent from my SM-J510FN using Tapatalk
SeanC is offline
post #5 of 6 (permalink) Old Apr 21st, 2017, 08:32 PM Thread Starter
Quoted: 9 Post(s)
Thanks guys!
I will give it a go with a ratchet spanner as suggested by WOE2. Fingers crossed ill succeed..
post #6 of 6 (permalink) Old Apr 21st, 2017, 09:33 PM
Quoted: 3 Post(s)
Thanks guys!
Worked for me and I only have 6 fingers so you should be fine.
I would post some pics but it's too much of a ball ache on this forum. I have pics over on the Facebook page 'JCW Clubman UK Register'.
WOE2 is offline
PANORAMIC SUN ROOF ISSUES -I'm in talks with Mini Head Office UK PLEASE READ/CONTACT LadyUK General Discussion 63 Oct 8th, 2015 05:56 PM
Cooper D turbo removal tips bluffin MINI Cooper Diesel 2 Apr 14th, 2015 10:57 AM
DIY: Changing the orange turbo seal MiniDeLux MINI Cooper Diesel 1 Dec 30th, 2014 11:43 AM
No Turbo boost,fault code 2884 charge air pressure control deviation Horsepower Jonny Welcome New Members 0 Jun 9th, 2014 06:43 PM
2007 R56 MCS Turbo blowing/damaged Sharkn3t Second Generation MINI Cooper S 6 Jan 23rd, 2013 10:02 AM
