Hi Everyone
I joined today as I need some help! My wife has a 2007 R56 Cooper and since we bought it we have had nothing but problems with it! Be glad to get rid if Im honest BUT yesterday she went out to the car, the remote fob wouldnt open the door, after a few seconds it opened, when she shuts the doors (either in or out of the car) the doors lock! It seems hit and miss as to whether the remote will work and we are worried she will get locked out of the car. If you are in the car, shut the door all doors lock, as soon as you put the hockey puck style key in the slot the doors unlock, I have no idea what Im looking at and need some advice.
About 3 weeks ago we had a new BMW battery fitted but it has been OK since then.
Sounds like the car's battery could be near the end of its life. My car's doors were locking the minute I started the engine without moving and all was cured when I chucked a new battery on the car!
Well that rules that one out unless the main dealer didn't associate the new battery to the car? Have you tried the other fob, I assume you have 2 remote fobs? This will rule out a flat battery in the fob. The only other things would be the body control module or another fault in the system, either a dodgy receiver or a wiring fault like a bad earth?
They didnt fit the battery as the guy on the service desk said they only need to fit and "reprogram" if its an AGM or EGM battery or something like that.
I am not sure its the actual remote key as like I say the doors seem to lock themselves simply by closig the door! Weird. However both keys give similar unlocking reults :-(
Who fitted the battery then? your ecu needs to see that the battery is new as (as far as I understand) all generation 2 cars batteries are AGM and need to be coded to the car
I fitted it mate, was quite straight forward, considering I dont have a clue
They said I would only need an AGM battery and recode if the car had Start Stop system, which it doesnt.
I would be checking to see if your model Mini has the IBS, if it has, you will need to have the ECU reprogrammed to allow it to know it has a new battery and how to charge it correctly, failure to reprogram the IBS ide of things will result in reduced battery life and may even damage your battery.
[Q] PLEASE NOTE: Not all MINI R56 models come equipped with an AGM type battery.*Not all R56 models come equipped with the IBS system. To determine if your R56 has this system you will need to look at the terminal end of the negative battery cable. [UQ]
Read the article on this link to identify if your car has IBS.
I have little faith in dealers too, more so BMW. My last warranty repair was abysmal and I had to repair the car myself in the end after they had it twice over 4 days. They couldn't even diagnose my fault which was blindingly obvious where and what the problem was. Then there was the paint job on my other Clubman.....
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
