Hello!
I had my MINI for a month, last week I decided to replace my timing chain tenisor to a new one. So I did, to ensure that the I will never face a problem with the timing chain. As it was swapped in 2012 by BMW because timing chain failure. Now the engine runs more smooth. BUT now I have noticed a rattle sound when Im turning the wheel around 1500-3k revs. And it's sound really loud and bad, like metal against plastic. The strange thing is when the car is stasionary and Im revving it, I can't hear the rattle.. no rattle at all... only when turning or the car in motion.
I also got a to messages about low oil pressure, when corning right, but it goes away after to seconds.. checked the oil, and it is where it should be at the pin..
Picture is from the old chain tenisor and the new chain tenisor orginal part from MINI, it was tighten to 65nm/48ibs as MINI say's.
What can it be?
Oil pump/vacuum pump?
Need help ASAP.
Greetings from Norway!
What can it be?
Need help ASAP.
