| Second Generation Interior & Ice Second Generation MINI interiors Late 2006 - Present |
| Googled a little bit more...... and then a bit more and eventually found Adding Speed Camera POI to your BMW Professional NAV DVD I've tried this out tonight and it works a treat Problem solved. Rob |
| Hi Dave, You won't screw anything up. You take the original nav dvd and extract the contents to an image. Then, working on the image you modify some of the config files to add then menu item for the cameras and add the files for the camera locations and the graphic icon. Once you've made the changes you burn the image to a blank dvd (or DVD-RW, although I've not tried this) and put it in the mini and see if it works. If not, then nothing lost you just put your original dvd back in and everything is as before. Rob |
| has anyone else managed to do this, messaged rob with no success? ![]() ITS HERE!!!!........R56 S, Sparkling Silver, Sat Nav, Redwood Red Lounge Leather, Sun Roof, web spokes, Colour coded arches click here... |
| R53 Sat Nav vs R56 Sat Nav | Perm | Second Generation Interior & Ice | 34 | Jun 22nd, 2008 04:16 PM |
| SAT NAV + Cameras! | benjacobs25 | First Generation Interior & Ice | 19 | Jan 11th, 2006 09:24 PM |
