| Second Generation Interior & Ice Second Generation MINI interiors Late 2006 - Present |
| What settings are you trying to change? From memory I can change most settings both with the engine running or not... as long as the key is in and the start button pressed. Might be more settings to play around with when the start button is pressed without the clutch, will have a check a bit later... ![]() |
| Make sure you select the correct option. There is one with a little ruler symbol and one with a tick. The ruler is for setting things like miles or km, the ruler one is for setting programming options. I can't remember whether you need the engine off or on, you certainly can't change things if you are moving! |
| ok with the aux on or off, or engine on or off.. no matter which combination i use i have none of these options. my only options are; - time & date that's it! bizarre ah. i wonder why this is. my 2nd remote only has 1 click for the half blinker setting. i want to change it to 3 and i can't. i'll have to ring BMW tomorrow. |
| you know when you hit the blinker half way, as the manual would put 'to the first pressure point'. well you can program how many times you would like the inidicator to flash, from 1 - 5. my default key is set to 3 standard. my spare is on 1. I want to change to 3 using the set/info menu. but i can't ![]() does that make sense |
| take a look at my how to enter the set menu at --> http://www.mini2.com/forum/2nd-gen-i...ml#post3085189 maybe this will help enjoy |
| Tags: key, programming, r56, remote |
| Key Programming | Marcucio | General Discussion | 26 | Nov 1st, 2006 06:55 AM |
| Remote programming - how much? | supa-dupa-cooper | General Discussion | 5 | Apr 21st, 2005 02:10 AM |
| Key programming ? | minimcbs | First Generation MINI Cooper | 3 | Jul 21st, 2003 12:15 AM |
| Programming Remote Key | mrnigelk | First Generation Faults & Fixes | 1 | Nov 4th, 2002 01:44 PM |
