| Second Generation Interior & Ice Second Generation MINI interiors Late 2006 - Present |
| Replacing factory stereo (suggestions wanted!) Hi all, First of I should say Hello as this is my first post here. I do not currently own a mini, but plan to purchase a 2008 cooper s this spring and I have some questions. Lets say I wanted to go with an aftermarket stereo rather then the HK premium radio upgrade (alpine iDA-X100 head end unit, some new component speakers for the front, a JL stealth box and an amp to drive it). I *do* plan to purchase the navigation system! My questions are: 1) Will I still be able to use the ipod connection and control my ipod from the steering wheel? 2) Will the navigation system still work? If so what will replace the "joystick" from the factory radio? How will this work? 3) Can I use the steering wheel controls with this alpine head unit? It says it supports steering wheel controls so I am guessing yes. 3) If I decide to not upgrade to this Alpine system and instead simply add a JL Stealth box sub to the premium sound system how easy is this to configure? (Does the premium system have a line out from the factory stereo where I can just add an amp?) Thanks guys, appreciate your suggestions! |
| Well if you go onto New Mini Stuff, Mikey does the correct looms to add amps etc. |
| Just to clarify. Unless DrSyn is talking about a 2008 Cooper S Convertible, then no you cannot change the head unit. The convertible is still the first generation and so you can change the head unit on these cars. |
| Guys its true you cannot replace the stereo in a R56 but its very easy to fit an additonal one in the upper glove box area behind the panel, and use the mfsw controls to operate the aftermarket headunit. So better still, it looks stock and all the best bits are hidden. |
| Tags: alpine, factory, ipod, replace, stereo |
| Replacing the original/factory oil | Sheenabea | First Generation MINI Cooper S | 2 | Aug 12th, 2006 02:23 AM |
| Replacing o repreograming the '04 h/k stereo | marco_er82 | First Generation Interior & Ice | 0 | Mar 3rd, 2005 06:31 PM |
| Replacing factory run flats ? | greatmeadows | Wheels, Tyres & Brakes | 9 | Nov 22nd, 2003 11:09 AM |
| Stereo System Upgrade! Suggestions PLEASE@!$ | pcmike | First Generation Interior & Ice | 10 | Mar 27th, 2003 04:26 AM |
| Replacing the 2002 Factory Stereo w/2003 Model | tic-tac | First Generation Interior & Ice | 14 | Sep 4th, 2002 11:22 PM |
