Miles to Kilometers - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 3rd, 2009, 08:45 PM
Local Time: 09:45 AM
Ireland Male View gfog's Astro Black & White 2nd Gen MINI One Profile
Ireland Miles to Kilometers
hello everyone,
does anyone know if its possable to have an r56 mini's speedo converted to km from miles and if so whats involved and prices if anyones undertaken it? i know i can change the digital read out in the setting but im just wondering about the speedo in the centre console.
Thanks in adavnce, cheers
Old Jun 3rd, 2009, 08:47 PM
adam_Randell's Avatar
Send a message via MSN to adam_Randell
Local Time: 08:45 AM
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile View adam_Randell's Classified Ads
you can get anything mate. but its gonna cost . you will need lots of work doing i should imagine. i was thinking of getting the new style speedo (80 mph is where the 70 mph is on the old one) but was thinking it would be too much work!
Old Jun 3rd, 2009, 09:06 PM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
Quote: Originally Posted by gfog (original)
hello everyone,
Should be just swapping a card over
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Jun 3rd, 2009, 09:09 PM
im not sure if thats easy think it may have to be re-calibrated? would love if someone could prove me wrong though.
ah, maybe. i was thinking it would be hard work coz i wanted to 80 where the 70 is, but yes. i see how it would work now
Old Jun 3rd, 2009, 09:35 PM
MINI One Seven
I'd imagine that its calibrated to be in the same position in mph and kph (the needle is as responsive as you can switch the digital display around) as it would be cheaper to make that way for mini!
Old Jun 3rd, 2009, 10:37 PM
caveman_dave's Avatar
United Kingdom Male View caveman_dave's Classified Ads
To change from km to miles is as simple as changing the face of the dial. The direct km to mph values will be in the correct place. ie 60mph will be very slightly before the position of 100kmh.
To change the face with the digits in new locations (ie 80 where 70 is) would require the speedo to the calibrated, but since the digital and analogue use the same outputs it would require a new servo motor behind the analogue clock and that would take some working out, or find someone that could remap the chip behind the speedo, and I am not sure that it would be that easy to get at the code let alone change it.
I dont need to make my car go faster, I just need to learn to drive it faster.
Old Jun 4th, 2009, 09:39 AM
i was just thinking surely if its as simple as changing the face of the dial, zero would be wrong then? as the needle would come to rest in the same place if you get me?
Old Jun 4th, 2009, 12:53 PM
DaFlake's Avatar
MMC Member
Local Time: 04:45 AM
They are two seperate part numbers....
RealOEM.com BMW R56 Cooper S Speedometer, instrument panel
I would imagine that you have to buy the cluster as the needle will move at a different pace on one than the other.
You could get the USA version that has both MPH and KPH.
Old Jun 4th, 2009, 11:17 PM
The only way to know for sure would be try and get some pictures of the different facia's for the speedo's one in mph and the other in kmh.
It appears that there are different versions even here in the UK, some have 70 mph in the centre uppermost postion and mine a Cooper D as 80 mph in the centre uppermost postion. This would imply that you would need to buy a facia that as the equivilent sppeds in the correct position.
Post a pic of yours and maybe we can identify a model in the UK that would give you the correct readings.
Kilometers only on speedometer? MrT-Man Canada 7 Nov 4th, 2005 05:21 PM
Change odometer to read in kilometers. cloonadra1 General Discussion 15 Jan 13th, 2005 03:00 PM
Cooper S: First impressions after 1000 kilometers KlausR First Generation MINI Cooper S 6 Jun 11th, 2003 01:17 AM
My MCS lasted for 506 kilometers Milorg First Generation MINI Cooper S 10 Aug 27th, 2002 09:24 AM
How many Miles/Kilometers did you get out of your classic MINI? MiNi General Discussion 12 Jul 31st, 2002 10:23 AM
