JCW convertible 2010 - speaker rattle / buzz - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 28th, 2011, 09:45 PM
Local Time: 04:11 AM
Luxembourg Male
Hi guys
I've been running my 2010 cabrio JCW for about 8 months now, and since new it has suffered from an annoying buzz / rattle from the passenger side rear speaker / trim panel, and it's particularly evident with music with deep bass. I have the HK hifi set up. Has anyone else had this problem, and is there an easy fix? I find that if I press hard onto the rear panel the vibration stops, so I wonder if it's a deadening / insulation problem, or a problem of a loose bit of trim inside the panel.
Phil
Old Mar 1st, 2011, 08:11 AM
Local Time: 03:11 AM
England Male View Boro Boy's Eclipse Grey & Body Color 2nd Gen MINI Cooper S Profile
I had this on my last MCS. After removing the trim (bit of a job), found it was one of the metal clips holding the trim to a metal edge of the bodywork vibrating. Took the clips off, stuck a strip of electicians tape along the metal edge, then refitted the clips, then the trim. Thankfully it worked!
Old Jun 9th, 2011, 09:19 PM
Luxembourg Male
So I took the car into the local dealer here in Lux, and under warranty they "changed all of the cables to the speakers". Can't understand how this would change the vibration and boominess, but it seemed to work. Today, playing a particularly bassy D'Angelo track, the booming is back. So, I clipped in the rear seat belts and, hey presto, problem solved. Obviously the issue was the seat belts just touching the trim and vibrating with the bass. I recall the seat belts were clipped in when the car came out of the dealer but hadn't made much of it. How stupid did I feel
Tags: , , ,
Harmon Kardon Speaker Buzz WissCooperS First Generation Interior & Ice 1 Nov 5th, 2007 04:41 AM
Speaker Buzz Mily First Generation Interior & Ice 10 Apr 14th, 2006 09:01 PM
exhaust rattle/buzz? RickB First Generation Faults & Fixes 4 Dec 14th, 2004 07:07 PM
Rear HK Speaker bass buzz grafiksguy First Generation Faults & Fixes 0 Aug 19th, 2003 02:18 AM
Rattle Buzz Buzz Rattle daro911 First Generation Faults & Fixes 13 Jul 18th, 2003 10:30 AM
